Wireless On/Off transmission
Hello everybody.
I am very new here so, excuse my beginners mistakes (if any).
Do you have an idea on how could I transmit wireless just a basic signal (on/off state of a contact) over a short distance (6-10ft or 2-3m)? The cheapest way possible at both ends (emission and reception point). Available power at both ends is DC.
Let's say, when the contact is closed (ON) in point A, I will have an LED ON in point B, but no wires between A and B. When contact is open in point A (OFF), I will have the LED in OFF state in point B. That's all.
Any ideas would be good.
Thanks a lot.
Thanks a lot.
Unfortunately, you've got two contradictory requirements ... that of having a really cheap solution and that of having a beginner's level of experience, presumably both hardware and software. You could try the bare 433MHz transceivers, but you're likely to have problems with noise / interference. You could also use a pair of xBee transceivers (see this guide). These can be used without a microcontroller once they're configured using a PC utility program, but they're not a really cheap solution.
And you might want to look over this thread a bit: http://forums.parallax.com/showthread.php/142431-I-would-like-suggestions-for-a-cheap-simple-radio-control-device-for-the-Propeller
