Anyone ever played with mega-brites?
Here is what I am trying to drive with the code the follows:
http://docs.macetech.com/doku.php/megabrite
I can't say that I completely get their arduino code snip in their sample ( for example, what the heck is going on in the while loops in the SB_SendPacket() function? ).
Anyhow, the code below "seems to work" but I am not completely convinced that I have the bit mixing correct. So on the chance that somebody had tried these devices before I thought I would post this for some other eyes to look it over.
Please don't bother to reply if you have to say something like "I have a solution but I won't post code here because blah-blah-blah" -- cuz frankly that kind of response does not help anybody at all.
Thanks, in advance, to anyone that may have some help for me here.
For more ideas on what can be done with these things, see:
http://mbed.org/users/4180_1/notebook/shiftbrite1/
' {$STAMP BS2pe}
' {$PBASIC 2.5}
DataPin PIN 0 ' data pin
ClockPin PIN 1 ' shift clock
LatchPin PIN 2 ' latch outputs
EnablePin PIN 4 ' output enable
RLED VAR Word
GLED VAR Word
BLED VAR Word
TOREVERSE VAR Word
REVERSED VAR Word
LO_WORD VAR Word
HI_WORD VAR Word
COUNTER VAR Byte
Setup:
LOW EnablePin ' turn on LED output
LOW LatchPin
LOW ClockPin
Main:
DO
FOR RLED = 1 TO 1000 STEP 30
FOR BLED = 1 TO 1000 STEP 20
FOR GLED = 1 TO 1000 STEP 10
GOSUB RGB_LED
PAUSE 1
NEXT
NEXT
NEXT
FOR GLED = 1000 TO 1 STEP -10
FOR BLED = 1000 TO 1 STEP -20
FOR RLED = 1000 TO 1 STEP -30
GOSUB RGB_LED
PAUSE 1
NEXT
NEXT
NEXT
LOOP
END
ReverseBits:
REVERSED = 0
COUNTER = 16
' DEBUG "INPUT: ", IBIN16 TOREVERSE
DO WHILE ( COUNTER > 0 )
REVERSED = REVERSED << 1
REVERSED = REVERSED | ( TOREVERSE & 1 )
TOREVERSE = TOREVERSE >> 1
COUNTER = COUNTER - 1
LOOP
' DEBUG " OUTPUT: " , IBIN16 REVERSED , CR
RETURN
DEBUG_WIRE_DATA:
DEBUG "BLED ", IBIN10 BLED , CR
DEBUG "RLED ", IBIN10 RLED , CR
DEBUG "GLED ", IBIN10 GLED , CR
DEBUG "HI_WORD/LO_WORD ", IBIN16 HI_WORD , "_" , IBIN16 LO_WORD, CR
TOREVERSE = HI_WORD
GOSUB ReverseBits
DEBUG "WIRE_BITS ", IBIN16 REVERSED
TOREVERSE = LO_WORD
GOSUB ReverseBits
DEBUG IBIN16 REVERSED, CR
RETURN
RGB_LED:
LO_WORD = 0
HI_WORD = 0
' HI_WORD = ( BLED << 4 ) | ( ( RLED & $3C0 ) << 6 )
' LO_WORD = ( ( ( RLED & $3F ) << 8 ) | ( GLED ) )
' 10bits G 10bits R 10bits B then two zeros
HI_WORD = ( ( BLED << 2 ) & $FFFC ) | ( ( RLED << 10 ) & $FC00 )
LO_WORD = RLED >> 6 | ( ( GLED << 6 ) & $FFC0 )
' GOSUB DEBUG_WIRE_DATA
SHIFTOUT DataPin, ClockPin, LSBFIRST, [HI_WORD] ' send the bits
SHIFTOUT DataPin, ClockPin, LSBFIRST, [LO_WORD] ' send the bits
HIGH LatchPin
PAUSE 1
LOW LatchPin
RETURN
