Need some programming help for solar system running on BS2p — Parallax Forums
pumpmckpumpmck Posts: 1
edited 2013-01-14 16:51 in BASIC Stamp
1st, I am not sure I am posting this like you would want as I am adding it a previous thread.
Hi
I have a solar system running on BS2p. I am trying to do some fine tuning to save space and I have an If statement that I can't seem to make work the way I want.
The sample code:
INPUT 8 'blue pb led
'DEBUG "S" ' ************************************
DEBUG "in8---",BIN IN8," sp--", BIN sp ' **********Solar Pump ***************
whspon = (~IN8 & ~sp) ' ************************************
whspoff =(IN8 & sp)
DEBUG " whspon--", BIN1 whspon,CR
' DEBUG "whspoff--", BIN1 whspoff,CR
I apparently am missing something as I can't seem to make these if statements work. CAN YOU HELP?
I have tried many different ways but so far can't seem to make the if statement work when I am trying to do a logical AND on two bit variables.
IF (~IN8=1 & ~sp=1) THEN sp=1:DEBUG "Solar pump turned on" 'water heater turned on
IF (IN8=1 & sp=1) THEN sp=0:DEBUG "Solar pump turned off"
" when I use the if statement like this it works like I want, but I am testing the variable that I am setting and I would like to eliminate the extra step
If (whspon=1) then sp=1:DEBUG "Solar pump turned on"
If (whspoff)=1 then sp=0: :DEBUG "Solar pump turned off"
  • SapphireSapphire Posts: 497
    It might be that you are mixing boolean and logical AND. The "&" character means boolean AND, and can be used in assignment and test. The logical AND operator, literally "AND" is used for comparison only (usually) and not assignment.
    So,
    should be
    IF (IN8=0 AND sp=0) THEN sp=1:DEBUG "Solar pump turned on" 'water heater turned on
    Also, how is sp defined? If it is a byte, ~sp will give unusual results. Better to test sp=0 than ~sp=1 because ~sp is not 1 when sp is 0, it's 255!
