Deterministic Timing Alogrithm — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2013-01-16 22:48 in Propeller 1
I'm looking for an algorithm that will work correctly with the Propeller CNT to run a snippet of code every n clock cycles.
The naive approach is something like this:
nextMatch = CNT + delayCycles
repeat
   while CNT < nextMatch do nothing
   nextMatch  += delayCycles
   //Do something
The problem with this code is that it will fail in the case that the addition to nextMatch rolls over the 32 bit value, and incorrectly satisfies the while condition.
The requirements:
1) The code should correctly account for CNT rollover
2) The code should be flexible enough for several events (ie, run task A every 100ms, task B every 230ms, and task C every 23ms)
3) The code should be posted as an algorithm, and not rely on any specific language features.
4) The hit on each cycle doesn't need to be exactly at the mark: it's ok if it has a bit of jitter. For example, a cycle that should take 100ms everytime:
Do something executed at:
100ms
210ms
302ms
400ms
543ms
600ms
Notice that it executes Do something once during every 100ms window, with a bias towards the beginning of the window.
5) Everything should be in the same cog.
6) Assume that the tasks take almost no time, i.e, you don't need to worry about the execution time of the tasks.
Background: I'd like to be able to read some external sensors. This collection of sensors has different update rates, ie. 300hz, 100hz, and 25hz. I could just read all the sensors at 300hz and "double log" the slower sensors data, but I would prefer to read each sensor at it's output frequency.
  • SRLMSRLM Posts: 5,045
    edited 2013-01-13 19:12
    Here is my first attempt:
    kReadPeriod = CLKFREQ/10; //Every 100 ms
    nextReadTime = CNT + kReadPeriod;
    currentCNT = CNT;
        //Case CNT = High and nextReadTime = Low
    if( (currentCNT>>31==1 && (nextReadTime<CLKFREQ)
    	return;
    	//Case CNT = Low  and nextReadTime = Low
    	//Case CNT = High and nextReadTime = High
    if( currentCNT > nextReadTime
    	//Case CNT = Low  and nextReadTime = High
       || ( currentCNT < CLKFREQ && nextReadTime>>31==1 ) )
    	//Do something
    	nextReadTime += kReadPeriod;
    This block should be called at least once every cycle that the code is expected to run. To run more than one task, simply make duplicates of the above.
    edited 2013-01-13 19:31
    Does task mean software task, or launch new cog to run the snippet(s)? Or something else?
    If its software tasking in the same cog, I thought there wasn't a nice say to do this without knowing the cycles required for each currently running task. Do we know how long the tasks run? Or can we assume that every candidate task will finish with sufficient time before the next task needs to start?
    edited 2013-01-13 19:36
    Good points. The answers:
  • pjvpjv Posts: 1,903
    edited 2013-01-13 19:47
    Hi SLRM
    The multi-tasking thread scheduler I have will do what you want. Unfortunately I am not permitted to release it under MIT license where it might end up being used for commercial applications. If your needs are strictly personal, then perhaps I can help you.
    The assembler scheduler code consumes a single cog and can repeatedly activate any number of events with one microsecond granularity.
    The repeat intervals can also be modified on the fly.
    Let me know if this is of interest to you.
    Cheers,
    Peter (pjv)
    edited 2013-01-13 20:19
    time := cnt
    repeat
      waitcnt(time += interval_cycles)
      'Do something
    edited 2013-01-13 22:02
    Try figuring the longest that your routine will take. Add a fudge factor (buffer if you like the term better) for the running time.
    Make the first step be to determine what the end_time = cnt+running_time is then do the routine. After it returns (hopefully ahead of end_time), wait until CNT = end_time and either do it again via a loop or repeat instruction or for a series of these, do the same as above for each needed item falling through to the next and at the end of all return and do again. Unless you are going to access the hub, and as long as none of the routines jumps the tracks and exceeds your end_time value, you should be ok. As to your concerns of comparison at boundary conditions where cnt <> end time you may need to figure an absolute value from the CNT and end_time and compare it with a fixed value so that when CNT has not rolled over and end_time is less than CNT you can correct for that event.
    Consider using the counters as an alternative as well. Determine the count needed for your time requirements, clock at 1/4 freq and set the value to be your time frame in instructions (or clock at freq/1 and the time in instructions being the clock cycles to run the routine. Then, do a waitpne or waiteq for the counter to run out once the routine finishes to repeat or move on to the next one.
    Haven't tried this, but not to far down the road it will probably come up....... Those would be the first two methods I would try if I had to do this......
    Frank
  • MicksterMickster Posts: 2,719
    edited 2013-01-13 22:27
    time := cnt
    repeat
      'Do something
    The point being that waitcnt compensates for rollover, right?
    Mickster
  • jmgjmg Posts: 15,183
    edited 2013-01-13 23:30
    SRLM wrote: »
    You did not mention the size of the tasks, or the precision needed.
    The 1ms LSB above, infers you need to resolve to whole 1ms time units ?
    If the tasks are shorter than this time-tick, then a simple solution is to run a precision 1ms timer, and then call-off every X,Y,Z counts.
    edited 2013-01-13 23:51
    pjv wrote: »
    Hi SLRM
    Thanks for the offer, but I would like to stick with less-restricted options for now. Still, I appreciate the nice word that you included: "scheduler". I like it much better than "timer."
    time := cnt
    repeat
      'Do something
    This won't fulfill requirement 2 (multiple tasks/periods). I thought about maybe adding three counters, and then using the waitcnt on the "next" one. That solution, however, requires the same rollover code.
    Frank
    Can you provide psuedo-code for the first one?
    I've also considered the counter alternative. I have code that will divide the system clock to put the current "time" in units of 1/2400th of a second (or some such odd number) into one of the counter registers. This would allow for the simple implementation of the scheduling algorithm, but a) it won't last for long (a couple of days?) and b) it's jittery for the non integer divisors of the unit.
    jmg wrote: »
    I don't have any hard requirements for the minimum or maximum time step.
  • Cats92Cats92 Posts: 149
    edited 2013-01-14 00:27
    People using Arduinos use schedulers as they have only one cog:
    If my memory is good they have a Open Source Scheduler Library in C.
    In the Arducopter programs (Ardupilot) perhaps you can find something like that.
    Try a Google search about that ?
    https://github.com/Zuph/AVRQueue ?
    Jean Paul
    edited 2013-01-14 07:52
    There's a method that very handy for small systems and microcontrollers.
    There's a software round robin for all the tasks. When a task is complete, it gives control to the next task in line.
    If a task does something that requires it to wait, it makes its request, then gives control to the next task in line.
    Using this method, its very easy to get the tasking loop completely deterministic. Just be sure to give up control periodically when doing somthing too long; for example yeild control at each iteration of a loop in a task. Of course the thing that we have to wait for will always take as long as they take, but they won't impact the rest of the system, since we just yield control while we detect we are waiting.
    We do this all the time in forth but it can be done in any language. http://dec.bournemouth.ac.uk/forth/forth.html#13
  • JonnyMacJonnyMac Posts: 9,191
    edited 2013-01-14 08:16
    I've attached a very simple scheduler that will do what you want. I'm flashing LEDs on a QS at different rates
    pub main
      timer1 := cnt + PERIOD_1
      timer2 := cnt + PERIOD_2
      timer3 := cnt + PERIOD_3
      repeat
        if ((timer1 - cnt) < 0)
          timer1 += PERIOD_1
          blip(16)
        if ((timer2 - cnt) < 0)
          timer2 += PERIOD_2
          blip(18)
        if ((timer3 - cnt) < 0)
          timer3 += PERIOD_3
          blip(20)
    pub blip(p)
      high(p)
      pause(25)
      low(p)
    Note that you were just a little bit off in how you calculated the end of the period; this version works -- I lifted the logic from the bit timing of FDS.
    edited 2013-01-14 08:18
    lastcnt := cnt
    repeat
      repeat while (cnt - lastcnt) < delaycycles
      lastcnt += delaycycles
      'do something
    This works even when cnt rolls over.
    edited 2013-01-14 10:31
    Jon's method will work. However, if you want to reduce power consumption and get the best timing accuracy, you can still use waitcnt thus:
    CON
      _clkmode      = xtal1 + pll16x
      _xinfreq      = 5_000_000
    VAR
      long  intvl0, intvl1, intvl2, intvl3
      long  time0, time1, time2, time3
      long  time
    PUB  start | i
      intvl0 := clkfreq * 10 / 1000
      intvl1 := clkfreq * 13 / 1000
      intvl2 := clkfreq * 20 / 1000
      intvl3 := clkfreq * 22 / 1000
      dira[0..3]~~
      time := cnt
      repeat i from 0 to 3
        time0[i] := time + intvl0[i]
      repeat
        waitcnt(time += (time0 - time) <# (time1 - time) <# (time2 - time) <# (time3 - time))
        if (time == time0)
          !outa[0]
          time0 += intvl0
        if (time == time1)
          !outa[1]
          time1 += intvl1
        if (time == time2)
          !outa[2]
          time2 += intvl2
        if (time == time3)
          !outa[3]
          time3 += intvl3
    Here's a snapshot of the output:
    One thing to pay attention to is the "time interval granularity," which is the greatest common divisor of all the intervals. In the above example, it's one millisecond. For this technique to work, the loop must always be able to complete in one granular unit of time.
    640 x 480 - 14K
  • MJBMJB Posts: 1,235
    edited 2013-01-14 14:01
    localroger wrote: »
    lastcnt := cnt
    repeat
      'do something
    Unfortunately this is not correct.. CORRRECTED!! this is wrong !!! see below.
    if lastcnt is close to rollover then the next interval will be too short.
    I tried a little and now I am wondering ...
    cnt is unsigned 32 bit
    but SPIN arithmetic is signed 32 bit isn`t it ??
    please enlighten my confusion
    OK I did it myself - SPIN is 32bit signed
    CORRRECTED!! - the arithmetic calculations with wrapping around behaviour can be simulated in high level languages like VB by following the + / - operation
    with a AND &hFF for 8-bit or what ever bit length is required. This prevents the overflow errors that normally occur.
    This confirms that localroger is right. sorry for the confusion.
    Example for 8-bit in VBA to run inside EXCEL
    Dim cnt As Long
    Dim lastcnt As Long
    Dim delaycycles As Long
    Sub tst1()
        delaycycles = 17
        lastcnt = delaycycles
       For i = 1 To 1000
             cnt = cnt + 1
             cnt = cnt And &HFF
        Selection.Value = i
        If ((cnt - lastcnt) And &HFF) < delaycycles Then
            lastcnt = (lastcnt + delaycycles) And &HFF
            Selection.Offset(0, 1).Value = 1
        Else
            Selection.Offset(0, 1).Value = 0
        End If
        Selection.Offset(1, 0).Select
       Next i
    End Sub
    edited 2013-01-14 22:31
    I think what you are looking for is "Synchronized Delays" which is explained starting near the bottom of page 219 of the propeller manual V 1.2.
    edited 2013-01-15 00:10
    BTW, the waitcnt instruction does not care about rollover. It is looking at them as unsigned 32 bit binary numbers. The cnt register goes from 00000000 to FFFFFFFF (hex) and starts over at 00000000. The waitcnt(Time += Delta) instruction also does unsigned binary math.
        Time := cnt			' lets assume cnt was 0 when this statement was executed
     repeat
        waitcnt(Time += Delta)		' lets assume Delta is $11111111
        !outa[0]
    After 15 times through the loop Time will be set to $FFFFFFFF, and once cnt reaches $FFFFFFFF it will exit the waitcnt instruction, execute the !outa[0] and repeat the waitcnt.
    The waitcnt(Time += Delta) will add Delta (11111111) to Time ($FFFFFFFF) so time will now equal $11111110, and the waitcnt waits until the cnt register equals that value.
    During this time the cnt register has gone from $FFFFFFFF to 0 and continued incrementing at the _clkfreq rate.
    edited 2013-01-15 00:35
    The main point is that waitcnt deals only with equality, which is neither a signed nor an unsigned relationship. The only time the signed/unsigned issue arises is when dealing with inequalities (i.e. greater-than or less-than).
    edited 2013-01-15 07:22
    That is exactly what I wanted to add as well ...
    AND this only works with using waitcnt and not by polling the CNT where you will easily miss the equality.
    To handle the polling version requires some more thought and manual handling of the wrap around.
    edited 2013-01-15 08:24
    ... which is what Jon accomplished successfully back in post #13.
    edited 2013-01-15 10:02
    MJB wrote: »
    Both yours and Phil's are valid points. This only works with waitcnt. By putting the code you want to execute in the repeat loop it will be executed at the desired rate as long as the code in the entire loop takes less time to execute than the waitcnt Delta time.
    edited 2013-01-16 16:51
    MJB wrote: »
    No it won't. It's an interesting property of this kind of binary math that, for addition and subtraction, it doesn't matter whether it's signed or unsigned; subtraction rolls over. The value (cnt - lastcnt) will always return the number of cycles between the current cnt and lastcnt as long as the difference is less than 31 bits.
    edited 2013-01-16 18:41
    The OP, apparently, has left the building. Is this discussion merely academic at this point?
    No, OP is testing out the various methods posted. It takes me a while, but I like to be sure of having a solid base. I've been able to write a test harness using the code that I put in post #2, but now I'm working on substituting Jon's code in to see if it's any better.
    As a side note, I'm using this algorithm to read I2C bus sensors. Each sensor comes with a different read frequency specified (150Hz, 100Hz, 25Hz, 20Hz, 1Hz, and 1Hz). So it's definitely practical.
