Remote control using IR Quickstart/Human Interface Combo
skylight
After making a complete fool of myself posting in an earlier thread about not understanding some of the demos for the Quickstart and Human Interface I spent the evening playing around with several objects from the OBEX and although a beginner with spin I've started to get a real feel for it and adapted an IR spin program from the exchange that now recognises the numbered keys 1-8 on a remote and turns on the appropriate LED with key 0 turning them all off, I feel i've acomplished something tonight and this will definitely encourage me to go forward with the propeller.
Below is the adapted code and attachment, thanks to Bob Belleville for the original code.
ir_reader_nec.spin
{{ ir_reader_demo.spin
Bob Belleville
This object receives input from an IR remote using
object ir_reader_nec.spin or ir_reader_sony.spin.
This is a good tool to use to build a table showing
the key code for each button.
see readme.pdf for more documentaton
2007/03/01 - derived from ir_reader_nec_show.spen
and tv_terminal_demo.spin
2007/03/03 - generalized for nec and sony objects
provide method to get device ID
2013/01/12 Adapted code to work with Quickstart/Human Interface Board combo
Lines added are commented "HIB Addition"
CON
'will NOT work at other speeds
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
_irrpin = 8 'ir receiver module on this pin HIB Addition changed from 0 to Pin 8 for Human Interface Board
_device = 0 'accept any device code
_dlyrpt = 6 'delay before acception code as repeat
VAR
OBJ
'select one rcvir and one term
rcvir : "ir_reader_nec"
'rcvir : "ir_reader_sony"
'rcvir : "ir_reader_rc5"
'term : "tv_terminal"
term : "serial_terminal"
PUB start | keycode, x
term.start(12) 'start the tv terminal
term.str(@title)
rcvir.init(_irrpin,_device,_dlyrpt,true) 'startup
dira[23..16]:=255 'HIB Addition
repeat
keycode := rcvir.fifo_get 'try a get from fifo
if keycode == -1 'empty try again
next
if keycode & $80
term.out("R") 'show repeated code
term.dec(keycode & $7F)
else
term.dec(keycode) 'show code
if keycode == 17 'HIB Addition
outa[16]:=1 'HIB Addition
if keycode == 18 'HIB Addition
outa[17]:=1 'HIB Addition
if keycode == 19 'HIB Addition
outa[18]:=1 'HIB Addition
if keycode == 20 'HIB Addition
outa[19]:=1 'HIB Addition
if keycode == 21 'HIB Addition
outa[20]:=1 'HIB Addition
if keycode == 22 'HIB Addition
outa[21]:=1 'HIB Addition
if keycode == 23 'HIB Addition
outa[22]:=1 'HIB Addition
if keycode == 24 'HIB Addition
outa[23]:=1 'HIB Addition
if keycode == 16 'HIB Addition
outa[23..16]:=0 'HIB Addition
sp
'device code is in low 16 bits
term.hex(rcvir.fifo_get_lastvalid,8)
nl
x := rcvir.fifo_debug 'show fifo head and tail pointers
term.dec(x>>16 & $FFFF) 'fifo head
term.out(":")
term.dec(x & $FFFF) 'fifo tail
nl
PUB sp
term.out(" ")
PUB nl
term.out(13)
term.out(10)
DAT
title byte "Push ir button for codes",13,13,0
ir_reader_demoHIB.spinir_reader_nec.spin
