Button Combinations Debounced with jm_debounce? — Parallax Forums
coryco2coryco2 Posts: 107
edited 2013-01-10 17:52 in Propeller 1
I am trying to debounce multi-button combinations with jm_debounce from the Object Exchange http://obex.parallax.com/objects/489/
It seems to work fine for OR-ing multiple buttons like this:
con
  BTN_A   = 0001 << 18      'pin 18
  BTN_B   = 0010 << 18      'pin 19
  BTN_C   = 0100 << 18      'pin 20
  BTN_D   = 1000 << 18      'pin 21
  BTN_E   = 0000 << 18      'pin 22
  BTN_F  = 0000 << 18      'pin 23
  BTN_MASK = BTN_A | BTN_B | BTN_C | BTN_D | BTN_E | BTN_F
  ACT_HI   = 1
  ACT_LO   = 0
obj
  btns : "jm_debounce"
PUB  Main  |  b
  btns.init(BTN_MASK, 25, ACT_HI)
  repeat
    IF b := btns.getbits(BTN_A | BTN_B)
         SomeMethod
    ELSE
        SomeOtherMethod
but not AND-ing...which is what I want to use it for:
PUB  Main  |  b
  repeat
    IF b := btns.getbits(BTN_A & BTN_B)
         SomeMethod
    ELSE
        SomeOtherMethod
Can this be made to work for debouncing when trying to detect only when two or more button are pressed in combination?
  • JonnyMacJonnyMac Posts: 9,836
    You must use ORing to combine single bits into a multi-bit value; by ANDing, you are always setting the mask to 0
    if (btns.getbits(BTN_A | BTN_B) == (BTN_A | BTN_B))
        so_something
    I think you may be taking the term OR too literally here. In the above snippet the single-bit masks are ORed together to form a multi-bit mask; in this case, both bits must be active for the expression to evaluate as true. In this case the code is only looking for BTN_A and BTN_B to be active at the same time.
