MEAS SPEC DT series
Hi everyone,
I'm currently doing a project that measures force of impact, and I'm trying to implement a MEAS-SPEC DT sensor in it, but I can't seem to find any programming information about it. the manufacturer's spec sheet (DT_Series.pdf) claims it can be programmed as a form of accelerometer, but it does not have any links or information on how one would go about doing this. I've tried finding schematics on how to set it up with a BS2, and programming information about these things online, but I can't seem to find anything at all.
I am fairly new to programming, and have only basic understanding of programming, so details would be much appreciated.
Any assistance would be appreciated, and I thank you all in advance.
pdf
174K
Your sensors are a very basic element and are meant to be signal-conditioned with amplifiers, filters and such before being fed into an a/d converter that the Stamp or other micro would read. Have you looked on the manufacturer's site for sample circuits or other application data?
Have a look on the 'net for a article or two on a wheatstone bridge strain gage connection. Your device can be used similarly. The signal is then amplified (search 'instrumentation amplifier') so that you have a (average) signal of several volts to feed into an analog to digital converter (LTC1298 works easily with a Stamp).
Cheers,
Also, I believe those devices are best for seeing impacts or sharp changes in force, not steady state values.
Would this type be the Ideal circuit?
A better sensor for you to use would be an accelerometer such as the MMA7455 (http://www.parallax.com/Store/Sensors/AccelerationTilt/tabid/172/CategoryID/47/List/0/SortField/0/Level/a/ProductID/585/Default.aspx) or a similar 3 axis accelerometer.
