Adjusting the GPS speed sensitivity
I am using the attached GPS for my Robo Magellan project. Standard Parallax Red GPS module.
https://www.youtube.com/watch?v=M8u0VsNM0II
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/gps/List/0/SortField/4/ProductID/703/Default.aspx
Right now the bot has to move at a fast walking pace in order to freshly update the position. In some ways this is nice as it acts as a filter but there are disadvantages.
Is there spin code that anyone has written that allows me to change the navigation speed threshold? I've looked over the documentation, and I cannot find such a command, but a lot of times, the forum knows more than what is published.
Steve
Steve
I looked over your code and have a question or two. How do I modify since my GPS defaults to 9600 baud?
Among my concern is getting the correct check sum value.
I looked at this site, but I'm not really sure what I need to input as the message string.
http://www.hhhh.org/wiml/proj/nmeaxor.html
Do I need to make changes to the DAT information as well for 9600 baud?
Steve
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 'SD Card pins: DO_PIN = 22 CLK_PIN = 23 DI_PIN = 24 nCS_PIN = 25 'Serial I/O pins: GPS_IN = 16 GPS_OUT = 17 PC_IN = 31 PC_OUT = 30 'Write indicator: LED_PIN = 26 'Unit ID: UNIT = "0" 'ASCII constants: CR = 13 LF = 10 OBJ sio : "FullDuplexSerial" gps : "FullDuplexSerial" sd : "fsrw" PUB start | ch, i gps.start(GPS_IN, GPS_OUT, 0, 4800) sio.start(PC_IN, PC_OUT, 0, 9600) sd.mount_explicit(DO_PIN, CLK_PIN, DI_PIN, nCS_PIN) filename[7] := UNIT dira[26]~~ waitcnt(cnt + clkfreq) gps.str(string("$PSRF100,0,4800,8,1,0*0F", CR, LF)) 'Switch to SiRF binary protocol at 4800,8,N,1 'Diable Static Navigation waitcnt(clkfreq + cnt) repeat i from 0 to 9 gps.tx(DisStatNav[i]) 'Switch back To NMEA Protocol Message ID 129, leave only GGA and RMC strings and keep speed at 4800 waitcnt(clkfreq / 2 + cnt) repeat i from 0 to 31 gps.tx(BackToNMEA[i]) repeat waitstr(string("$GPRMC,")) getstr(@time, 10) 'if (time[5] == "0" or time[5] == "5") gps.rx if (gps.rx == "A") gps.rx getstr(@lat, 9) waitstr(string("N,")) 'Change to "S" for southern hemisphere. getstr(@lon, 10) sio.str(@time) outa[26]~~ 'Turn LED on during write, so it won't be interrupted by flipping off the power. sd.popen(@filename, "a") 'Open the file to append data. sd.pwrite(@time, strsize(@time)) 'Write the time and position line to the file. sd.pclose 'Do a close to stat the file. outa[26]~ 'Turn off the LED. else sio.tx("*") PUB waitstr(strptr) | ptr, match ptr := strptr repeat while match := byte[ptr++] if (gps.rx <> match) ptr := strptr PUB getstr(strptr, len) repeat len byte[strptr++] := gps.rx DAT filename byte "gpsdata_.txt" time byte "dddddd.ddd," lat byte "ddmm.mmmm," lon byte "dddmm.mmmm",13,0 'SiRF Disable Static Navigation, Message ID 143 DisStatNav byte $A0,$A2,$00,$02,$8F,$00,$00,$8F,$B0,$B3 'Switch back To NMEA Protocol Message ID 129 at 4800 bauds, leave on GGA and RMC strings updating oce per second. BackToNMEA byte $A0,$A2,$00,$18,$81,$02,$01,$01,$00,$01 byte $00,$01,$00,$01,$01,$01,$00,$01,$00,$01 byte $00,$01,$00,$01,$00,$01,$12,$C0,$01,$61 byte $B0, $B3
