No more AT24C1024B? — Parallax Forums
No more AT24C1024B?
localrogerlocalroger Posts: 3,452
edited 2013-01-07 18:49 in General Discussion
I just got an obsolete part notice from Digi-Key on the AT24C1024B, the 128 kbyte 1 MHz IIC EEPROM. Their suggested replacement for it is the 400 KHz Microchip part. And also isn't the Microchip part the one that can't be linearly addressed out to 512K with four chips? This seriously crimps a plan I've been working on for a year and a half. Anybody know what's up with this and if there are other options?
    edited 2013-01-07 16:57
    Stock up now: DigiKey only has 33,509 in stock:
    http://www.digikey.com/product-detail/en/AT24C1024B-TH25-B/AT24C1024B-TH25-B-ND/1886127
    You can stack them next to the pile of Walmart eReaders you (and I) are hoarding. :)
    edited 2013-01-07 18:41
    Whoa, you scared me!
    It turns out that it is a process upgrade and the pin and function equivalent 1M part will be the AT24CM01
    http://www.atmel.com/devices/AT24CM01.aspx
    It does look like they are dropping the DIP8 and DFN package, but the new part# will be available in soic and tssop.
    Change Description:
    Atmel has optimized the layout of the 1-Mbit AT24C1024B Industrial Temperature Grade Serial EEPROM. The catalog part number AT24C1024B will be replaced by AT24CM01 (see Table 1). The new devices are pin-to-pin and functionally backward compatible with the current AT24C1024B devices with the following exception and enhancement.
    In order to increase manufacturing flexibility and to ensure a long-term continuity of supply, Atmel will manufacture all package options using both gold (Au) and copper bond (Cu) wires. Atmel reserves the right to ship devices with either gold or copper bond wires.
    Losing the DIP8 is a PITA but I guess not the end of the world. I will need to figure out how to justify expensing a few dozen in case I get to the point of populating the thru-hole boards I have on hand.
