Strange behavior
A program I am writing starting behaving in a strange way and I managed to duplicate its behavior in the code I am posting bellow. I solved the problem by inserting an extra statement which I think serves no purpose.
If you comment out the "pinLow(16);" statement the sits in the " while(received_data->blink_now == 0x00)" loop of the blinker function the program will not work. I don't see what this statement does as in my opinion it is totally useless.
I run this program on a Propeller Professional Development Board where I wired one of the switches to pin 17 and an LED to pin 16.
Your comments will be appreciated.
Enrique
#include <propeller.h>
#include "pin.h"
typedef struct data_block
char blink_now;
} data_block;
data_block actual_data;
char stack[160];
void blinker(data_block *received_data)
pinOutput(16);
pinLow(16);
while(1)
pinLow(16); // If you comment out this statement the program will not work
while(received_data->blink_now != 0x00)
pinHigh(16);
waitcnt(CLKFREQ / 10 * 2 + CNT);
pinLow(16);
int main(void)
pinInput(17);
actual_data.blink_now = 0x00;
cogstart(blinker, &actual_data, &stack, sizeof(stack));
while(1)
if(pinGet(17) == 0)
actual_data.blink_now = 0x01;
else
return 0;
Enrique
Try -O0 (Oh Zero, that is no optimization).
while (received_data->blink_now != 0) ;intoif (received_data->blink_now != 0) for(;;); /* loop forever */Eric
I have the compiler set to Board Type: Hub, Compiler Type: C, Memory Model: LMM and Optimization -O2 Speed. With these settings the program behaves as I have described.
When I set the compiler to -O0 None, as you suggested, the LED blinks continuously.
I also followed Eric's suggestion and changed the code as follows but it didn't help.
Enrique
typedef struct data_block { volatile char blink_now; } data_block;It isn't the pointer that is volatile. It is the field in the structure.Enrique
The stack is the problem (+ need for volatile).
Calculating the minimum stack size is better than using a number which can be arbitrary.
The cogstart web page had 160 bytes minimum (wrong, sorry). The actual need is 176+ longs.
https://sites.google.com/site/propellergcc/documentation/libraries/propeller-h-library#TOC-cogstart
The minimum stack size is this:
int stacksize = sizeof(_thread_state_t)+sizeof(int)*3;
int stack[stacksize]; // valid with C99 ... use malloc otherwise.
Also, &stack to cogstart is wrong. If you want to use &, it should be &stack[0].
--Steve
On the link that jazzed posted, I noticed that "size" doesn't have any units. It mentions that the minimum is 176 longs, so maybe (int) is the unit. Which would seem to contrast with other references that say size is in bytes: http://www.cplusplus.com/reference/cstdlib/malloc/
Also, it would be nice to mention where the stack goes, just to clarify. ie, hub, cog, external(?), etc.
The stack always goes in hub memory, even in XMM modes.
Eric
Yes, sizeof(type) returns number of bytes used by type. So the expression sizeof(_thread_state_t)+sizeof(int)*3 should return number of bytes needed for the stack. Sorry for the confusion.
The original program does work using these changes: 1) volatile char blink_now, 2) &stack[0] or stack instead of &stack as the third parameter to cogstart, and 3) 176 bytes of stack as int stack[176/4+1] (the stack as a general rule should have N bytes evenly divisible by four) ... additionally, the stack size should be calculated but the code I mentioned before should use int stack[stacksize/4+1] rather than int stack[stacksize].
The answer seems to be yes (if it's used by multiple cogstart'ed functions, it must be volatile).
