Temeprature Compensated Oscillator — Parallax Forums
ul5255ul5255 Posts: 14
edited 2013-01-07 23:24 in Propeller 1
Hi guys,
I have this temp. compensated 10MHz oscillator (0.1ppm) which I'd like to use to precisely clock
the Propeller (I do know that 10MHz clock input is slightly out of spec ...).
My question is this however:
The output of this oscillator is AC coupled at approx 2.4V V_pk_pk.
Can this be used to clock the Prop or do I need a biasing circuit which lifts the signal so it swings
from 0V to 2.4V (or up to 3.3V)?
  • SapiehaSapieha Posts: 2,964
    edited 2013-01-07 07:01
    Hi ul5255.
    Use 7414 else like Schmitt trigger to buffer it
    http://www.nxp.com/documents/data_sheet/74HC_HCT14.pdf
    ul5255 wrote: »
    Hi guys,
  • ul5255ul5255 Posts: 14
    edited 2013-01-07 07:09
    Thanks for the reply but I'm afraid the problem remains:
    The 7414 data sheet lists as recommended operating conditions for Vi
    0V as minimum. My little oscillator swings down to - 1.2V.
    Also the max positive swing is just 1.2V which will not be recocnized
    as logic high even if I run Vcc down to 2.0V, right?
    edited 2013-01-07 07:17
    Hi.
    You have not posted any link to datasheet -- So I can't answer that
    ul5255 wrote: »
  • AribaAriba Posts: 2,694
    edited 2013-01-07 09:43
    Here are two possible circuits.
    1) Lifts the AC signal to the middle of the 3.3V range with 2 resistors. The Osc mode of the Propeller must be XINPUT
    2) Enables the inverter and feedback resistor inside the Oscillator circuit of the Propeller, so the AC signal is biased to the threshold voltage of the inverter input. Use XTAL3 or XTAL2 mode for this.
    Andy
    332 x 270 - 2K
  • eldonb46eldonb46 Posts: 70
    edited 2013-01-07 21:16
    ul5255 wrote: »
    Hi guys,
    ul5255
    Here is a "search" of my Blogged adventure with a TCVCXO and the Propeller, part numbers and part sources are included within the blog.
    Of course as with any blog, you really need to read the blog backwards to follow the project, and there are "Older Posts" of the beginning of the adventure (see link at bottom of each blog page).
    http://wa0uwh.blogspot.com/search/label/TCVCXO
    I
    hope this helps and inspire your efforts.
    Eldon - WA0UWH
  • jmgjmg Posts: 15,199
    Ariba wrote: »
    If the OP checks the value of the internal cap in his TCXO, then he may even be able to omit the 100pF, and simply join to XI
    The effect of a 'large' internal value like 100nF would be a longer time to settle with the high feedback resistor.
