Propeller Controls Apple iPhone — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2013-01-10 00:02 in Propeller 1
Just saying, you can control the new Apple iPhone
with the Propeller chip and it's talking speech program
using Apple's new Siri, a kind of listening, speaking
and task performing intelligence.
New AI Siri - (ideas, functions, interfacing, future)
http://humanoidolabs.blogspot.tw/2013/01/big-brain-new-ai-friend-siri.html
Propeller Speech Synthesis
Creating Brain Speech Synthesis - Intro to Propeller Speech
http://forums.parallax.com/showthread.php/124495-Fill-the-Big-Brain?p=977506&viewfull=1#post977506
Propeller Speech Recognition
http://forums.parallax.com/showthread.php/124495-Fill-the-Big-Brain?p=976721&viewfull=1#post976721
Post 303 Brain Speech Recognition Talk to the Brain in your own language
Post 305 Creating Brain Speech - Parallax Propeller Takes the Lead as Speech Synthesizer Chip
    edited 2013-01-07 06:44
    You've got to pay attention to the details ...
    To activate Siri for each transaction, you have to press and hold the iPhone's front button until Siri beeps twice. It won't respond to voice input until that point. You could hack an earphone / microphone cord using a reed relay to "press" the equivalent button and you could have access to the audio input and output the same way (hacking). This is not a big deal, but you have to do it before you can use Siri.
  • RaymanRayman Posts: 16,271
    edited 2013-01-07 10:17
    I wish Apple hadn't made it so difficult to interface with the iPhone...
    I thought I heard that Bluetooth v4.0 was going to make it easier, but can't find a specific example of a user doing this...
    There are devices like this though that may let us use this new "Bluetooth Smart" mode:
    http://www.blueradios.com/BR-XB-LE4.0-S2.pdf
    edited 2013-01-07 10:54
    That's a very good idea, Mike. I have a robot servo on hand, so without hacking the iPhone, the same Propeller chip can turn a Parallax servo horn to activate iPhone's button. A small round piece of cork or rubber helps preserve the surface of the switch. The OBEX routine moves the servo a proper amount and a small timing algorithm keeps track of the hold-down time.
    edited 2013-01-07 11:13
    Rayman wrote: »
    I wish Apple hadn't made it so difficult to interface with the iPhone... I thought I heard that Bluetooth v4.0 was going to make it easier, but can't find a specific example of a user doing this... There are devices like this though that may let us use this new "Bluetooth Smart" mode: http://www.blueradios.com/BR-XB-LE4.0-S2.pdf
    It's designed to be simple with devices "discoverable" automatically. I've only worked with it a day so far with good first step results - for example, just set the Apple Wireless keyboard next to the new iPhone and make sure it's not already connected to another Bluetooth device. I'm planning to use Bluetooth as part of a craft, with the iPhone, launched into Near Space. I've heard Apple has improvement updates for the new version in the works.
    edited 2013-01-08 03:21
    Humanoido wrote: »
    ...the same Propeller chip can turn a Parallax servo horn to activate iPhone's button.
    Another simple option bypasses the new iPhone's mechanical switch. It uses the free "built into the OS" virtual on-screen assisted touch-switch and requires a small setup. Go to Settings, General, Accessibility, turn on AssistiveTouch, go back to home, and position the Power Ball to an unused space. Put a small stylus on the servo to tap the Power Ball and the Siri button will come up in the same place every time. Match this position with the Power Ball or a servo. Now the servo(s) can use the stylus to activate both the Power Ball switch and Siri when necessary. The details can be worked out with position and a Propeller chip controlling servo(s), timing, and audio.
    edited 2013-01-08 07:55
    I just saw the voice stuff work on an android phone. I don't use the voice stuff much (kids are sleeping, etc) but it might be easier on android.
  • LtechLtech Posts: 388
    edited 2013-01-09 13:25
    iapp "my cmd" spinneret, network and udp
    and free
    edited 2013-01-09 16:08
    Ltech wrote: »
    and free
    Is there a link for this and description of how it can be operated with the Propeller chip?
    Spinneret = propeller & network : http://forums.parallax.com/forumdisplay.php/82-Spinneret-Web-Server
    Code for led on led off spinneret: http://spinneret.servebeer.com:5000/gstart/get.htm
    My cmd for Iphone : http://fotoventus.cz/mycmd.php or Itunes "my cmd" .....
