Unable to disconnect USB to 232 serial adapter
spiProgrammer
Hi I just got the USB to 232 Serial adapter, it works great, driver loaded right away. If I unplug the USB cable from the PC, the adapter will not reconnect to the PC unless I reboot the PC, also the PC will not shut down properly when the adapter has been unplugged. If I leave the adapter connected and shut down the PC it shuts down just fine only takes a few seconds, but if I disconnect the adapter the PC hangs during shut down. Is there a way to turn off the USB to 232 adapter before unplugging it? Or is there some technique that I am missing?
Thank you for any help
To describe the problem further, I just unplugged the USB to 232, then replugged, I get no tone, only one flash of the red light on the USB to 232 board, but minutes later the light is not green. When I firstboot the PC I get a tone when I plug in the USB to 232, a red flash, then a steady green light.
I'll try unistalling the Basic Stamp editor, and reinstalling. Is there a place to unistall the driver for the USB to 232? I'll also try the USB to 232 out on another PC, to rule out a possible hardware problem. I'll follow up after I make these test.
I tested my USB to 232 on a different PC, and it works fine, so I agree it is a problem with the original PCs setup. I'll work on that issue, and report if I find a fix.
Thank you for your advise,
