Maximum Solder Paste Wait Time
Does anyone know if there is a maximum time between the point where solder paste (and SMD components) are placed on the PCB and when the PCB must be put through the baking process? In otherwords, if I want to put half of the SMDs down tonight and wait until tomorrow to do the rest before baking will there be a problem? Solder paste is QuikChip brand SMD291AX.
I called quik chip before i wrote this post and they pointed me here...
http://www.digikey.com/product-search/EN?mpart=SMD291AX&vendor=315
Ask them again?
Anyhow, what you are looking for is "tack time" and the Amtech Syntech datasheet sadly avoids declaring this. However, the web page for the paste states:
wider process windows (12-18 hour stencil life, 18-24 hour tack time)
A tack time of 18-24 hours is rather long for solderpaste, so I would have to see it to believe it personally (but I also have not used pastes with synthetic flux materials). Kester EP256 is rated at "8+ Hr Tack Time" which is much more common with no-clean, tin-lead pastes. Basically any paste begins drying out after about ~4 hours. Once that begins, the performance of the flux begins to deteriorate, thus reducing the quality of your reflow process. You may be able to gain some time by placing the pasted board in a fridge in an airtight container to prolong the paste life.
Because putting anything giving off solvent fumes in a fridge should set alarm-bells ringing.... Door switch = spark, solvent = explosive atmosphere.
They did this as a safety demo for graduates - by blowing up a fridge. Classic example is ether, still highly volatile at -50C...
For one small board its not an issue due to the small amount of solder paste, but done on a larger scale could be extremely dangerous.
