Just got a WIZNET 812MJ
Started with the demo@ http://spinneret.servebeer.com:5000/
Looking at the Spinneret Web Server code, I'm trying to figure out what to do about the RTC since I have none. I've though about using one of the RTC emulators or possibly just disable them? Any advice from the experts would be greatly appreciated.
Also plan on using in SPI mode. I see that the driver is not directly compatable with Indirect Addressing object??
The new stuff, which I suggest, is also located in Google code
Checkout the Html5Graph.spin, that's a pretty good demo. Really, the only things you need to do is make sure the IO (hardware/software) is configured correctly or as expected.
Also, the later does not require an RTC. However, in both cases, if using the FAT engine, the RTC driver can be turned off in the FatEngineWrapper by entering a -1 for the I2C arguments in the start method.
Mike- I checked out this site but don't find anything to download.
I'll have a bunch more questions soon, still need to play with this a bit more.
Huge thanks for the quick response guys
'from w5100 PUB Suspend spi.Stop PUB Restore spi.resumeCog 'from spi cog PUB Start(p_cs, p_sck, p_mosi, p_miso) if not cog 'Init Parameters _cmd := 1 'Pin assignments _sck := p_sck _mosi := p_mosi _miso := p_miso _cs := p_cs Cog := cognew(@startSpi, @_cmd) + 1 repeat while _cmd result := cog PUB resumeCog if not cog _cmd := 1 Cog := cognew(@startSpi, @_cmd) + 1 repeat while _cmd result := cogI also added code to start cog if not running
PUB Write(addr, numberOfBytes, source) ' validate if (numberOfBytes => 1) IF NOT cog resumeCog 'wait for the command to complete repeat until _cmd == 0 .. .. PUB Read(addr, numberOfBytes, dest_buffer_ptr) | _index, _data, _spi_word ' test for anything to read? if (numberOfBytes => 1) IF NOT cog resumeCog repeat until _cmd == 0 .. ..The top level code, port of dnsDemo
PUB Init | ptr, url, ansRRS, i,d tch.beginDesktop("S") ' warmBoot font := tch.Loadfont(string("4x6.ifn")) ' black on white 16 point, load and set font to file tch.SetOrientation(false) tch.Clearscreen(tch.GetBackFontColor) ' clear screen to BackFontColor = font file loaded above tch.SetCurx(0) ' return Cursor to X 0 tch.SetCury(0) ' return Cursor to Y 0 buffPtr := @buff ansRRS := 0 tch.SelectMemGroup tch.TextT(font,string("Initialize")) tch.crlf tch.SelectSPIGroup 'wiz.QS_Init wiz.HardReset(WIZ#WIZ_RESET) wiz.Start(WIZ#SPI_CS, WIZ#SPI_SCK, WIZ#SPI_MOSI, WIZ#SPI_MISO) 'Loop until we get the W5200 version 'This let us know that the W5200 is ready to go repeat until d := (wiz.GetVersion > 0) pause(250) if(i++ > ATTEMPTS*5) DebugStr(string("W5200 SPI communication failed!")) return wiz.HardReset(RESET_PIN) wiz.SetIp(10, 10, 10, 107) wiz.SetMac($0F, $08, $DC, $16, $F8, $01) sock.Init(0, UDP, 53) sock.RemoteIp(10,10,10,1) sock.RemotePort(53) debugStr(string("version ")) debugHex(d,8) tch.crlf url := @url5 repeat CreateTransactionId($FFFF) FillTransactionID bytemove(@urlBuff, url, strsize(url)) byte[strsize(url)] := 0 debugStr(string("URL: ")) debugStr(@urlBuff) tch.crlf 'Copy header to the buffer bytemove(buffPtr, @msgId, DNS_HEADER_LEN) 'Format and copy the url ptr := ParseUrl(@urlBuff, buffPtr+DNS_HEADER_LEN) 'Add the QTYPE and QCLASS bytemove(ptr, @QTYPE, 4) ptr += 4 DisplayMemory(buffPtr, ptr - buffPtr, true) ptr := SendReceive(buffPtr, ptr - buffPtr+1) GetRcode(ptr) debugDec(rcode) debugStr(string(": ")) debugStr(RCodeError) tch.crlf if(rcode == 0) ansRRS := ParseDnsResponse(ptr) repeat i from 0 to ansRRS-1 ifnot(GetResolvedIp(i) == NULL) debugStr(string("ip_")) debugDec(i) debugChar($20) PrintIP(GetResolvedIp(i)) tch.crlf pause(2000) PUB debugStr(strptr) wiz.Suspend tch.SelectMemGroup tch.TextT(font,strptr) tch.SelectSPIGroup wiz.restore PUB debugChar(char) wiz.Suspend tch.SelectMemGroup tch.SetCurx(tch.textChar(font,char,tch.GetCurX,tch.GetCurY)) tch.SelectSPIGroup wiz.restore PUB debugDec(value) | x ,i wiz.Suspend tch.SelectMemGroup {{Send value as decimal characters. Parameter: value - byte, word, or long value to send as decimal characters.}} x := value == NEGX 'Check for max negative if value < 0 value := ||(value+x) 'If negative, make positive; adjust for max negative tch.SetCurx(tch.textChar(font,"-",tch.GetCurX,tch.GetCurY) ) 'and output sign i := 1_000_000_000 'Initialize divisor repeat 10 'Loop for 10 digits if value => i tch.SetCurx(tch.textChar(font,(value / i + "0" + x*(i == 1)),tch.GetCurX,tch.GetCurY)) 'If non-zero digit, output digit; adjust for max negative value //= i 'and digit from value result~~ 'flag non-zero found elseif result or i == 1 tch.SetCurx(tch.textChar(font,"0",tch.GetCurX,tch.GetCurY)) 'If zero digit (or only digit) output it i /= 10 'Update divisor tch.SelectSPIGroup wiz.restore PUB debugHex(value, digits) wiz.Suspend tch.SelectMemGroup {{ Send value as hexadecimal characters up to digits in length. '' '' `Parameters: '' '' `value: byte, word, or long value to send as hexadecimal characters. '' `digits: number of hexadecimal digits to send. Will be zero padded if necessary. '' '' `Return: none. '' '' `Example: pst.Hex(1234, 5) '' '' Output decimal 1234 as five hex digits. Outputs `004D2. '' Next lines, if needed... }} if (digits > 8) repeat digits - 8 tch.SetCurx(tch.textChar(font,"0",tch.GetCurX,tch.GetCurY)) digits := 8 else value <<= (8 - digits) << 2 repeat digits tch.SetCurx(tch.textChar(font,(lookupz((value <-= 4) & $F : "0".."9", "A".."F")),tch.GetCurX,tch.GetCurY)) tch.SelectSPIGroup wiz.restoreEverything else is stock. Any thoughts would be greatly appreciated as always!Spi5100CounterPasm.Spin
PUB Start(p_cs, p_sck, p_mosi, p_miso) 'Init Parameters _cmd := 0 'Pin assignments _sck := p_sck _mosi := p_mosi _miso := p_miso _cs := p_cs cog := cognew(@startSpi, @_cmd) + 1 PUB Stop if cog cogstop(Cog~ - 1) PUB ReStart cog := cognew(@startSpi, @_cmd) + 1 PUB Write(addr, numberOfBytes, source) ifnot(cog) ReStart ' validate if (numberOfBytes => 1) 'wait for the command to complete repeat until _cmd == 0 _iobuff := source _len := numberOfBytes _cmd := ($F0 << 24) + (addr << 8) + byte[source] repeat until _cmd == 0 ' return bytes written return( numberOfBytes ) else ' catch error return 0 PUB Read(addr, numberOfBytes, dest_buffer_ptr) | _index, _data, _spi_word ifnot(cog) ReStart ' test for anything to read? if (numberOfBytes => 1) repeat until _cmd == 0 _iobuff := dest_buffer_ptr _len := numberOfBytes _cmd := ($0F << 24) + (addr << 8) + 0 repeat until _cmd == 0 ' return bytes read return( numberOfBytes ) else ' catch error return 0W5100.spin
I'm not a fan of ReStart logic in Read and Write Methods. It works but I'd rather explicitly invoke Start and ReStart.
I'm not sure about the OR gate mentioned. Please post a schematic.
A hardware reset can take up to 1.5 seconds to take affect. Registers R/W will function while socket commands may not. That's been my experience.
Google code has been updated with the latest. The socket library and W5100 can better handle large file downloads. I did not add the ReStart logic to Google code.
