Boe-Bot and Bluetooth
Hello,
I was looking for an easy way to add wireless bluetooth programming and control to my Boe-Bot. I've seen serial to bluetooth adapters out there, but wanted to know if anyone here has had experience with them. This is the one I was looking at:
http://www.usconverters.com/index.php?main_page=product_info&cPath=65&products_id=228&gclid=CNK1od7IzLQCFYN_Qgod-yMAGw
It's inexpensive and sounds like it should work, if I use external power.
Does anyone have any thoughts on this, or other EASY options that don't require soldering to get bluetooth going for the boe-bot?
Joe
Joe
Note that the FlashFly modules, while wireless, don't use Bluetooth. They use the xBee standard. If you're going to use this, you'll want the Blue Wolf Adapter as well for your serial BoeBot.
