*HELP* Cool Double Digit Count Up with Pushbutton! — Parallax Forums
ShaneKShaneK Posts: 9
edited 2013-01-03 06:36 in BASIC Stamp
Hello,
I have written a somewhat simple program and wired a basic circuit that allows me to count up to 99 from zero on two seven digit displays using a pushbutton. The way I programed this I needed to use 13 of the 15 pins to control each of the individual LED's in the seven digit displays and 1 other pin to control the pushbutton state. I am trying to find out if there is a better way to program and wire this without the need of DIRH and OUTH. Maybe I could use a transistor or two but I have never used them and would need a bit of explanation. If anyone could help me please tell me how by replying. I would really appreciate it.
Also, here is the code that I used to program the BASIC Stamp.
' {$STAMP BS2}' {$PBASIC 2.5}
' Pins 0 through 7 control the bottom, bottom left, bottom right, and decimal points.
' Pins 8 through 15 control the middle, top left, top right, and top.
' This most definiteately needs to be wired on a seperate breadboard.
left [B]VAR[/B] [B]BYTE[/B]
right [B]VAR[/B] [B]BYTE[/B]
counter [B]VAR[/B] [B]BYTE[/B]
PINNUM [B]VAR[/B] [B]NIB[/B]
time [B]CON[/B] 350
left = 0
right = 0
[B]DO[/B]
    [B]IF[/B] (right = 0) [B]THEN[/B]
        [B]GOSUB[/B] right0
    [B]ELSEIF[/B] (right = 1) [B]THEN[/B]
        [B]GOSUB[/B] right1
    [B]ELSEIF[/B] (right = 2) [B]THEN[/B]
        [B]GOSUB[/B] right2
    [B]ELSEIF[/B] (right = 3) [B]THEN[/B]
        [B]GOSUB[/B] right3
    [B]ELSEIF[/B] (right = 4) [B]THEN[/B]
        [B]GOSUB[/B] right4
    [B]ELSEIF[/B] (right = 5) [B]THEN[/B]
        [B]GOSUB[/B] right5
    [B]ELSEIF[/B] (right = 6) [B]THEN[/B]
        [B]GOSUB[/B] right6
    [B]ELSEIF[/B] (right = 7) [B]THEN[/B]
        [B]GOSUB[/B] right7
    [B]ELSEIF[/B] (right = 8) [B]THEN[/B]
        [B]GOSUB[/B] right8
    [B]ELSEIF[/B] (right = 9) [B]THEN[/B]
        [B]GOSUB[/B] right9
    [B]ENDIF[/B]
    [B]IF[/B] (left = 0) [B]THEN[/B]
        [B]GOSUB[/B] left0
    [B]ELSEIF[/B] (left = 1) [B]THEN[/B]
        [B]GOSUB[/B] left1
    [B]ELSEIF[/B] (left = 2) [B]THEN[/B]
        [B]GOSUB[/B] left2
    [B]ELSEIF[/B] (left = 3) [B]THEN[/B]
        [B]GOSUB[/B] left3
    [B]ELSEIF[/B] (left = 4) [B]THEN[/B]
        [B]GOSUB[/B] left4
    [B]ELSEIF[/B] (left = 5) [B]THEN[/B]
        [B]GOSUB[/B] left5
    [B]ELSEIF[/B] (left = 6) [B]THEN[/B]
        [B]GOSUB[/B] left6
    [B]ELSEIF[/B] (left = 7) [B]THEN[/B]
        [B]GOSUB[/B] left7
    [B]ELSEIF[/B] (left = 8) [B]THEN[/B]
        [B]GOSUB[/B] left8
    [B]ELSEIF[/B] (left = 9) [B]THEN[/B]
        [B]GOSUB[/B] left9
    [B]ENDIF[/B]
    [B]DO[/B]
    [B]LOOP[/B] [B]UNTIL[/B] ([B]IN3[/B] = 1)
    [B]PAUSE[/B] 200
    [B]IF[/B] (right < 9) [B]THEN[/B]
        right = right + 1
    [B]ELSEIF[/B] (right = 9) [B]AND[/B] (left < 9) [B]THEN[/B]
        right = 0
        left = left + 1
    [B]ELSEIF[/B] (right = 9) [B]AND[/B] (left = 9) [B]THEN[/B]
        [B]GOSUB[/B] reach99
    [B]ENDIF[/B]
    'IF (right < 9) THEN
    '    right = right + 1
    'ELSEIF (right = 9) AND (left < 9) THEN
    '    right = 0
    '    left = left + 1
    'ELSEIF (right = 9) AND (left = 9) THEN
    '    GOSUB reach99
    'ENDIF
[B]LOOP[/B]
[B]right0:[/B]
    [B]LOW[/B] 12
    [B]HIGH[/B] 4
    [B]HIGH[/B] 5
    [B]HIGH[/B] 6
    [B]HIGH[/B] 13
    [B]HIGH[/B] 14
    [B]HIGH[/B] 15
    [B]RETURN[/B]
[B]right1:[/B]
    [B]LOW[/B] 4
    [B]LOW[/B] 5
    [B]LOW[/B] 13
    [B]LOW[/B] 14
    [B]RETURN[/B]
[B]right2:[/B]
    [B]LOW[/B] 6
    [B]HIGH[/B] 4
    [B]HIGH[/B] 5
    [B]HIGH[/B] 12
    [B]HIGH[/B] 14
    [B]HIGH[/B] 15
    [B]RETURN[/B]
[B]right3:[/B]
    [B]LOW[/B] 4
    [B]HIGH[/B] 6
    [B]HIGH[/B] 15
    [B]RETURN[/B]
[B]right4:[/B]
    [B]LOW[/B] 5
    [B]LOW[/B] 14
    [B]HIGH[/B] 13
    [B]RETURN[/B]
[B]right5:[/B]
    [B]LOW[/B] 15
    [B]HIGH[/B] 5
    [B]HIGH[/B] 14
    [B]RETURN[/B]
[B]right6:[/B]
    [B]LOW[/B] 14
    [B]HIGH[/B] 4
    [B]RETURN[/B]
[B]right7:[/B]
    [B]LOW[/B] 4
    [B]LOW[/B] 5
    [B]LOW[/B] 12
    [B]LOW[/B] 13
    [B]HIGH[/B] 14
    [B]HIGH[/B] 15
    [B]RETURN[/B]
[B]right8:[/B]
    [B]HIGH[/B] 4
    [B]HIGH[/B] 5
    [B]HIGH[/B] 12
    [B]HIGH[/B] 13
    [B]RETURN[/B]
[B]right9:[/B]
    [B]LOW[/B] 4
    [B]LOW[/B] 5
    [B]RETURN[/B]
[B]left0:[/B]
    [B]LOW[/B] 8
    [B]HIGH[/B] 0
    [B]HIGH[/B] 1
    [B]HIGH[/B] 2
    [B]HIGH[/B] 9
    [B]HIGH[/B] 10
    [B]HIGH[/B] 11
    [B]RETURN[/B]
[B]left1:[/B]
    [B]LOW[/B] 0
    [B]LOW[/B] 1
    [B]LOW[/B] 9
    [B]LOW[/B] 10
    [B]RETURN[/B]
[B]left2:[/B]
    [B]LOW[/B] 2
    [B]HIGH[/B] 0
    [B]HIGH[/B] 1
    [B]HIGH[/B] 8
    [B]HIGH[/B] 10
    [B]RETURN[/B]
[B]left3:[/B]
    [B]LOW[/B] 0
    [B]HIGH[/B] 2
    [B]RETURN[/B]
[B]left4:[/B]
    [B]LOW[/B] 0
    [B]LOW[/B] 1
    [B]LOW[/B] 10
    [B]HIGH[/B] 9
    [B]RETURN[/B]
[B]left5:[/B]
    [B]LOW[/B] 11
    [B]HIGH[/B] 1
    [B]HIGH[/B] 10
    [B]RETURN[/B]
[B]left6:[/B]
    [B]LOW[/B] 10
    [B]HIGH[/B] 0
    [B]RETURN[/B]
[B]left7:[/B]
    [B]LOW[/B] 0
    [B]LOW[/B] 1
    [B]LOW[/B] 8
    [B]LOW[/B] 9
    [B]HIGH[/B] 10
    [B]HIGH[/B] 11
    [B]RETURN[/B]
[B]left8:[/B]
    [B]HIGH[/B] 0
    [B]HIGH[/B] 1
    [B]HIGH[/B] 8
    [B]HIGH[/B] 9
    [B]RETURN[/B]
[B]left9:[/B]
    [B]LOW[/B] 0
    [B]LOW[/B] 1
    [B]RETURN[/B]
[B]reach99:[/B]
    [B]FOR[/B] PINNUM = 0 [B]TO[/B] 15
        [B]LOW[/B] PINNUM
    [B]NEXT[/B]
[B]END[/B]
Shane Kent
    edited 2013-01-02 19:03
    Actually, DIRH and OUTH (and DIRL & OUTL) is the easy way to do it. Are you trying to avoid using them?
    I'd do one digit on OUTL and the other on OUTH, which would use the same bit pattern for each digit. Do you want/need the decimal point to move? Could you just hardwire the DP on? That would simplify and give you 2 pushbuttons, maybe one for down and one for up.
  • RDL2004RDL2004 Posts: 2,554
    The Stampworks manual has several chapters devoted to using seven segment displays with the Basic Stamp and overall it's a pretty good introduction to somewhat more advanced Basic Stamp programming.
    It's available as a free .pdf download here:
    http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
    You'll probably want to keep the BS2 manual handy to read the details about how some of the commands work.
