Indistinguishable Colors
Vega256
Hey,
While looking at the Prop's full color gamut, I noticed that colors with luma values 4 and 5 are indiscernible and/or are the same color altogether. Does anyone know why this is, and perhaps a solution?
Once a particular hue gets bright enough (over 30%), yes, visually to us variations in brightness don't look that much different. Also, TV's aren't linear in their signaling, either (equal steps up or down do not produce equal changes in visible brighness).
There are many ways to produce color television. The point is how involved do you want it to be, what your end goal is, and how many other people besides yourself would bother to build the circuit if you wanted other people to try your game or software?
It could also be the display is "crushing" the luma values. Some displays have a gamma setting that can cause this. If VGA, check that. If TV, are you using a newer TV or older CRT one? And are you using RF modulator or straight composite connection?
I suspect the resistors too, but it could be a display thing. Try various adjustments and or a "factory" mode, if the display has one.
This can happen in the driver too. Are you running a Parallax one, or a custom one? Which one?
