Wall sensing robot code help — Parallax Forums
gizahunagizahuna Posts: 1
edited 2012-12-30 16:03 in Accessories
I am extremely new to programming and working with two students on this project. I have a 2WD robot chassis, arduino uno, motor shield, and Parallax ping sensor. We are attempting to build a wall sensing robot. We have the motors coded to run and even headlights (wow factor for 5th graders), but unfortunately we (and especially me) can't figure out how to write the code so the sensor will stop the robot when it comes close to a wall.
The code is below: Any help you someone can provide will be great.
// names the LED and pin number
int led = 10;
int led2 = 6;
int work = 0;
// this constant won't change. It's the pin number for the sensor
// of the sensor's output:
const int pingPin = 7;
//sets the interger for the pulse sensor
int distance;
unsigned long pulseDuration=0;
void setup() {
  //Setup MOTOR RIGHT
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
  //Setup MOTOR LEFT
  pinMode(13, OUTPUT); //Initiates Motor Channel A pin
  pinMode(8, OUTPUT); //Initiates Brake Channel A pin
  //SETUP LED HEADLIGHTS
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  pinMode (led2, OUTPUT);
  // initialize serial communication: SENSOR
  Serial.begin(9600);
void loop() {
  lightson();
  moveforward();
  pingsensor();
  turn();
  //blinkers();
void lightson() {
  // the loop for the LED to run as a headlight
  digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
  digitalWrite(led2, HIGH); //TURN THE LED2 ON (HIGH IS THE VOLTAGE LEVEL)
void moveforward() {
  //Motor A forward @ full speed (left motor)
  //full speed of motor is 255
  digitalWrite(12, LOW); //Establishes forward direction of Channel A left motor
  digitalWrite(9, LOW); //Disengage the Brake for Channel A
  analogWrite(3, 239); //Spins the motor on Channel A
  //motor B forward @ full speed (right motor)
  digitalWrite (13, HIGH); //Establishes forward motion of Channel B right motor
  digitalWrite (8, LOW); //Disengages the brake for Channel B
  analogWrite (11, 254); //Spins the motor on Channel B
void pingsensor() {
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  Serial.println();
  delay(100);
long microsecondsToInches(long microseconds) {
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second). This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: [URL]http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf[/URL]
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds) {
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
void turn() {
  if (pulseDuration < 10 & pulseDuration > 5){
    // stop motors
    //engages the brake for left motor
    digitalWrite(9, HIGH);
    //engages brake for right motorch
    digitalWrite (8, HIGH);
    delay (5000);
    //turns robot to another direction
    //digitalWrite(12, HIGH); //Establishes REVERSE direction of Channel A left motor
    //digitalWrite(9, LOW); //Disengage the Brake for Channel A
    //analogWrite(3, 239); //Spins the motor on Channel A
    //digitalWrite (13, LOW); //Establishes REVERSE motion of Channel B right motor
    //digitalWrite (8, LOW); //Disengages the brake for Channel B
    //analogWrite (11, 100); //Spins the motor on Channel B SLOWLY
  else{
    work = work + 1;
    edited 2012-12-29 21:09
    Hello gizahuna - welcome to the Forum!
    Please be aware that this is a forum for Parallax oriented products. However, this is a friendly bunch and will attempt to assist if possible.
    I've edited your code sample to make it more readable.
    edited 2012-12-30 13:12
    Please read the PING documentation. It goes into some detail on how the sensor works. Basically, you trigger it and it sends out an ultrasonic pulse and signals the Stamp or Arduino that the pulse has been sent. When the first echo from the pulse is received, the PING signals the Stamp or Arduino that the echo has been received. The Stamp or Arduino has to measure the time it takes from when the pulse is sent until the echo is received. There's code on the Arduino website that does this and converts the time into a distance measure (inches or centimeters). Your code has to periodically measure this distance with the PING as the robot is moving, then stop the motors if the distance is less than some value you choose.
  • garyggaryg Posts: 420
    edited 2012-12-30 15:27
    I have no experience with Arduino, However:
    If you pay carefull attention to Mike Green's comments and are able to understand exactly how the Ping works,
    the position of your ping unit relative to the robot platform is very important.
    In my projects, If I'm mounting the ping to detect a wall, what works best for me, is to mount the ping at about a 45 degree angle from
    front position.
    When you read the distance using the ping, the 45 degree mounting angle allows you to measure the distance to the wall before you are at the location. If I am looking directly at the wall, I usually crash.
    I've mounted my Ping unit on a servo that can pivot to where I want the Ping to look that is independent of the platform.
    My only recent Microcontroller experience is with BS1 and BS2 Parallax controllers.
    Sorry I can't help with the Arduino code.
    garyg wrote: »
    +1. For a simple diff-drive robot, your PING sensor needs to be pretty far ahead of your drive wheels, so a small turn will rotate the chassis and move the sensor relative to the wall even before the wheels move. Easier to see in this video, where the bot "porpoises" off the wall to follow it. That is, there are only two modes. Steer away from the wall if the sensor sees it, or steer towards the wall if the sensor doesn't see it. This robot has a seperate front obstacle sensor to enable left turns.
