DMX board for Quickstart
Does anyone know if a DMX I/O board for controlling lighting has been made for the Quickstart? I've seen the DMX objects in the OBEX but wondered if anyone knows a source for the hardware compatible with the Quickstart? I don't have the facilities to make a board myself.
I have made a number of DMX boards that I can interface to either the Quickstart or any other Parallax offering. And it is all done on protoboard or strip board. Very easy as there are plenty of DMX interface circuits on the interweb that you can use.
Does this help?
One thing with the protoboards is the concept, do they have strips on the back like strip board or are they just a matrix of holes? If the latter how are multiple connectons achieved, do components legs bend to one point at the back and soldered together or is it a wire wrap and/or solder bridge solution?
Edit I investigated the parallax protoboard for the quickstart and there was a diptrace layout which I used to get a 3D image of to rotate, some tracks are there but the prototyping area is mainly just holes,so if I were to use IC's for instance I'd solder a base and then wire to the legs with multiple wires or take component legs to the pins? or is there a simple way of creating strips with these boards to convert to strip board ie is there enough gap between hole rows to lay a bare wire? It does seem to be a bit cumbersome or am I getting the concept wrong? Is there a tutorial somewhere on the Parallax site using these boards?
Sorry to ask such a dumb question but i#ve never used a protoboard before
Basic Propeller circuit on a proto-board
edit: You can use the leads of things like LEDs and caps like wire. Don't twist wires or leads together, just use solder like glue and try to only have one connection per pad (not three or more wires or leads coming together). It's easier to solder this way and makes repairs or modifications much easier. Make sure everything is clean and shiny before starting to solder.
Although it may not be good practice the holes are close enough to bridge with solder too to make tracks, of course i'd make sure that any components legs were through the board first before making the bridges.
Much obliged for the information.
Besides having to worry about the bus traces localroger mentioned, many of Parallax's proto boards also have a ground plane. If you make a solder bridge over part of the ground plan you run the risk of shorting your connection to ground. Even a little too much solder on a pin can cause a short to the ground plan (ask me how I know). The solder resist isn't always solder proof.
I'd avoid having any solder make contact with an area of the board that may have a gound plane.
If the board has a ground plane, I use insulated wire when making connections. I often uses a little piece of heatshrink tubing if there's some bare wire I'm afraid may eventually cause a problem.
A lot of proto boards don't have a ground plane. The board Rick showed in post #4 doesn't have a ground plane so running a length of bare wire isn't a problem.
This the best picture I could find among those in my "manage attachments" folder.
This is the bottom of a Propeller Protoboard. You can see the traces for rx, tx and reset running across the bottom or the board. I scraped solder resist of the traces to add a header for a Prop Plug. (This was originally a USB protoboard but I cut the USB part out to use as a Prop Plug.) Between the traces the blue is a slightly different color than other areas of the board since there isn't any ground plane between these traces.
The seven holes on the bottom left of the picture show the holes being connected to the ground plane.
Here's a small piece of bare protoboard.
The large holes around the edge don't have the ground plane around them. You can see how the board on the left of the picture is a little thicker than the board on the right. If you look closely you can see the side copper on the left side.
The rest of these are more of my DIY Prop Plug.
