Dealing with mains voltage and high currents — Parallax Forums
CSA ProductionsCSA Productions Posts: 2
edited 2012-12-31 12:47 in BASIC Stamp
Relatively new to the Basic Stamp and have just a few questions.
1) what would be the safest and most durable way to sense the presence of 120V AC with a pin on the BS2. I'm not a stranger to dealing with this type of need, just want to protect the (seemingly) delicate chip -and keeping in mind worst-case scenarios such as lightning surges or large machinery inductive kicks.
2) similar to 1) but in reverse, -how to reliably drive large solid-state relays (30A) with good isolation back to the controller when they fail? Should I use a small mechanical relay to drive the big ones? Should there be an optical isolator?
3) Is there a way to carry a program through a power loss to the BS2? something along the line of "process not completed due to shut-down so resume where we left off when power returns?"
-Thank you for any advice.
    edited 2012-12-28 08:35
    CSA - welcome to the Forum!
    Grenora?!? Wow, you're way up there!
    Optical isolation would certainly be the way to go...and there are a number of Forum members who have used the BS2 in an industrial environment. They'll be chiming in soon, I'm sure.
  • tonyp12tonyp12 Posts: 1,951
    edited 2012-12-28 11:55
    A PS2505 is the way to go.
    pull-up from the Vcc line should be around 10k
    Ohm Resistor to use on the main, 47k should be OK for 110v and 100k for 220v.
    http://www.mouser.com/_/N-scv7?Keyword=PS2505&Ns=Pricing%7c0&FS=True
    623 x 632 - 78K
    edited 2012-12-28 12:39
    A less sophisticated 120VAC detector could be as simple as a NE-2 neon bulb and a photocell.
  • CSA ProductionsCSA Productions Posts: 2
    edited 2012-12-28 12:45
    tonyp12 wrote: »
    http://www.mouser.com/_/N-scv7?Keyword=PS2505&Ns=Pricing|0&FS=True
    Thank you, that's just the ticket, -and the 2505-4 gives you four of them in one $2 package -much simpler than some of the methods I was dreaming-up.
    How long is the output low-signal at zero-crossing (60Hz) -is it possible to accidentally poll a 0 if you hit it at that moment?
    edited 2012-12-28 13:11
    You could read twice slow,and if at least one is high for true...
    Or even better read 100 times pretty fast and if 20 or more high = true (software debounce)
    Or a RC snubber (a 33k series resistor plus a 1uF cap to gnd) on the line going to the input-pin, to filter out the 2% low state.
  • willembadwillembad Posts: 47
    I built one for my project to detect if a compressor was running or not. Used a 120VAC LED designed as an appliance ON indicator light and heat-shrinked it to a photodiode. Had to poll multiple times since the stamp is fast enough to catch 50 Hz off.
    In the following code "Compressor" is an input Pin 0
    [FONT=arial][COLOR=#333333]SysCheck:[/COLOR]
    FOR Counter2 = 1 TO 10
       Run = Run + Compressor
    NEXT
    IF Run = 0 THEN ShutDown
    Run = 0
    IF CurrentMix > 380 THEN ShutDown
    [COLOR=#333333]RETURN
    [/COLOR][/FONT]
    1024 x 620 - 85K
