SMD Soldering Question
After much thought and research I finally broke down and bought this Soldering/Rework Station. http://www.ebay.com/itm/110969755108?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I have been quite ill and though it ws a Christmas gift to myself I have not been well enough until today to set it up. This unit shows lots of promise and I am thus far very satisfied with its performance and capabilities.
I have not tackled SMD components as of yet and I purchased an SMD Practice kit so I can learn. Here's my question: Is there any documentation that outlines maximum temperatures to use for specific components such as resistors, leds, capacitors, etc or does it depend on the manufacturer? I want to make sure to get off on the right foot by not burning up everything I try to solder from the start.
Get feeling better......
Frank
Google was the short answer. depends on how you will attach the parts. There are lots of charts and curves for doing bulk soldering in toaster ovens etc, you will have to refer to the data sheets that the paste manufacturer distributes with their product. Air baths help in the component repair and individual component placement. (I also use my work unit to scavenge SMT parts, the air pen works so much better at removing multi-pin devices. Practice makes speed) The trick to removal for me was getting the right balance of airflow and heat. Have not successfully removed any BGA devices yet. May try again when we get the digital controlled air bath unit.
Oh, invest in a good set of specialty tools like this set http://www.zeph.com/soldering_supplies_kits_bga_smd_smt_thru-hole.htm from Zephtronics. Good curved tweezers work almost as well as an vacuum pick up for me on smaller parts. Personally I am not a fan of lead free. But you can go both ways with these kits.
I'm guessing it's mostly for the P&P machine vision, not for humans. Plus, where else would you put it?
In any case, most components are fairly robust. I have a couple of boards where the chips on them have been reflowed up to 210C about 10 times. Ideally, you would follow a solder reflow profile.
http://www.kester.com/LinkClick.aspx?fileticket=OUPpdDgnu4U%3D&tabid=181
