In light of the recent threads regarding software licensing, where does this fit in?
While perusing some information regarding the I2C bus structure and its use in projects, I found this note in one of the Philips app notes from 20003, and it reads:
I2C Patent and Legal Information
The I2C bus is protected by patents held by Philips. Licensed IC manufacturers that sell devices incorporating the technology already have secured the rights to use these devices, relieving the burden from the purchaser. A license is required for implementing an I2C interface on a chip (IC, ASIC, FPGA, etc).
It is Philips's position that all chips that can talk to the I2C bus must be licensed. It does not matter how this interface is implemented. The licensed manufacturer may use its own know how, purchased IP cores, or whatever. This also applies to FPGAs. However, since the FPGAs are programmed by the user, the user is considered a company that builds an I2C-IC and would need to obtain the license from Philips.
Apply for a license or text of the Philips I2C Standard License Agreement
US and Canadian companies: contact Mr. Piotrowski (pc.mb.svl@philips.com)
All other companies: contact Mr. Hesselmann (pc.mb.svl@philips.com)
Now, for us garage and hobby level designers, no biggie, I doubt if they care a wit (no offense Whit) about us, but what about those doing project kits, or possibly larger projects and commercial production using the Prop chip. No, it is not technically an I2C bus at least in hardware, but the above would appear to include anyone implementing a soft I2C interface to the peripherals in their design must also apply to Philips (or NXP) for the license to utilize the same for commercial or even non-commercial purposes.
Just wondering what the consensus is out there. I believe this may be a good example of the type of awareness that Bruce had brought up in the run of one of the licensing threads......
Frank
hmm.
Halon ... check
temp alarms .... check
asbestos undies .... check
POST
Frank
hmm.
Halon ... check
POST
I²C on Wikipedia
FF
I stumbled on this statement at the rear of a Philips manual (circa 2000) a couple years ago. Later I came across another Philips manual, circa 2005-ish, that had removed the restriction on user-created I2C implementation. Unfortunately, I can't remember either manual's name. I'll dig deeper when I'm back at work next week.
Lifting the restriction is a good thing for the company where I work, as we generate the I2C bus protocol via our own methods. If the restriciton had still been in place, we would be a tempting target for Philips' legal team!
a) They had to come out with re-designed devices that no longer had SD card support
b) Due to the above, the whole Open Software support for TomTom satnav devices basically disappeared, the device became a closed system so that even if it runs Linux there's no easy practical way to work with the device and load new/more software.
-Tor
I'm happy staying below the radar....
I don't understand:
1) Why would Tom Tom have to remove SD card support just because they cannot use FAT? There are many other file systems that can be used.
2) Given 1) above open source thing would thrive very well using an alternative file system.
Makes no sense to me.
Now, wouldn't it be cool if the Tom Tom devices came with ext3, say, for SD cards and their user instructions included the message "We are sorry to all users of Windows but the maker of your operating system does not allow us to create an easy to use interface for you, we suggest using an alternative OS". If all camera and other gadget makers did the same that would soon put and end to that nonsense, one way or another.
If a hardware gizmo like I2C is patented then the method is necessarily published, in the patent, and is public information. It's published by the government so so it is actual public domain, not subject to copyright.
The above means I can write a description of it and give it to you with no strings attached. That's why we have patents.
That description could be the source code of a program that implements the gadget on your Propeller.
Ergo, there is no need for any licensing to be attached to that source code. It is a derived work of a public domain publication and copyright does not apply. Ergo, attaching an MIT license to it is not necessary and should in fact be ineffectual. In fact attaching your own license terms to a public domain work is probably even violating some section of law or other.
Of course using such source to create a program running a real Prop product would then still be a patent infringement.
-Tor
