help is needed for CMUCam with Boe-Bot
waleedfakhr
Hello everyone;
We bought a parallax Boe-Bot then bought the CmuCam later from Parallax which is supposed to work for the boe-bot.
this is for the senioe project of my students. So far, they have a problem in hooking the camera to the boe-bot since there are
2 pins which are supposed to be for the power but there is plcae for them on the boe-bot board, I know this is very basic
question, but we need some help.. Thanks
Dr. Waleed
Dr. Waleed
It might be easiest if you power it with 5V from one of the BOE's servo ports. If you're not using both pan and tilt servos, it looks like you could use one of those connections to power the board from the BOE. I think I'm wrong about the servo connectors. It looks like the servos get powered separately from the rest of the board. You may need to make a custom cable to make this connection since I don't see a power connection option (on the camera board) which would allow a standard three pin connector.
Another option for powering the board would be to use the BOE's Vin and connect to one of the "Vin" locations on the camera board. IIRC, the BOE has a jumper to set the servo connectors to either Vin or 5.0V. So depending on which way you have this jumper set, you'll want to use either a Vin or a 5.0V connection on the camera board.
Are you using a BS2 Board of Education with your BOE-Bot or is your BOE a PropBOE?
Does it look lik 1 or 4?
CMUcam 1
CMYcam 4
It is the CmuCam-1, and I bought it from Parallax 6 months ago as they say it is designed for the boe-bot.
do I have a mismatch problem now? is there a way to make this cmucam-1 work with the boe-bot?
many thanks
Waleed
A Google search for Parallax cmucam lead me to this forum thread http://forums.parallax.com/showthread.php?70824-Parallax-CMUcam-Information-and-Contest but the product links are dead. If you contact Parallax tech support they should have a zip of the documents and code samples.
