Question about routers, switches, etc...
I have a combo unit DSL modem with wired and wireless router built in. I have 1 computer in my office that is connected via wire. So in this office I'd like to split the connection to add another computer that sits next to the first one and also have a spare port that I could plug the Spinneret into. So maybe something with 4 ports.
What is it that I need to make this work?
What do I need to look out for?
Thanks.
Don
Thanks.
Don
Can't think of anything to look out for. It really is pretty much plug and play for these bits of hardware.
I have a multi-port router feeding 2 8-port switches. Just running 9 computers at the moment. ;-)
The wireless is nice and convenient, however, the Ethernet ports are generally faster and should be used if possible.
Duane J
So it sounds like all I need to do is go to Staples or Walmart and get a "switch" and connect it up and let it fly?
Are there any problems then trying to access the Spinneret through the router --> switch combination from the web?
I have no experience with the spinneret so I can not answer this question, but I would suggest buying a router rather than a switch. There is very little difference in the price and the router is more likely to work over the web.
TRENDnet TEG-S50G
Plug and go, no software or drivers needed. Plug this switch into the router, then all the computers into the switch. My router is only 10/100, so this also gives me 1000Mbps between the computers.
Technically routers and switches serve two very separate functions and aren't interchangeable. That said most routers have switches built into the same package but don't have to.
If you're "internal" network is all on the same subnet then a switch is what's called for. Connect it to your DSL router and you'll be good to go. If you have multiple subnets in your house (if you do I'd like to know why :-) ) then you need a router to route traffic between. (not true in every case but close enough) I got a 5 port asus gigabit switch at Microcenter for under $40 and of course after less then a month I went back and found that since then Asus released an 8 port gig switch for ~$5 more :-(
I live close enough to stop by and help get you setup if you need help. Feel free to PM me if I can help.
Frank
If you want to access the spinneret from outside you need to configure the router. Look for port redirection or a similar function. Then map the outside port 80 to the spinneret address.
Many routers have a built in support for dynamic dns services, very useful unless you have a public static IP.
Massimo
Late to the game..... Nevermind.......
Just drop a 4 port switch between the computer and the dsl modem. Then after you hook up the cpu, you will still have 2 or 3 ports for wired use. Maybe consider an 8 port. These are pretty cheap if you don't need a router function (if the dsl modem handles it, otherwise replace the term switch with switch with built-in router but it sounds like your dsl modem does have a routing function) The wireless should work as before. As to the spinneret, question will be to the router and that is does the spinnerett use DHCP or static IP address. if static. Then you may have to look at thd modem setup to see how it divies up the static and dhcp ranges. I started DHCP at 192.168.1.100 and higher. Below .100 is all static. You may do things differently.....
