Post a link to a thread at another forum? — Parallax Forums
ArduitoArduito Posts: 4
edited 2012-12-22 10:59 in General Discussion
Hello everyone,
I posted a question at arduino.cc/forum about a parallax item on an Arduino board, and I wanted to see if someone here may be able to answer it too.
I read the forum guidelines about cross-posting, but I wasn't sure if this only meant not to post the same item multiple times at the forums.parallax.com:
No cross-posting:
Cross-posting is: 1) submitting a post to one forum or thread, and then submitting a second linking to the original post (without changing content or intent), or 2) creating an identical post in more than one forum or thread. When the same content is found in more than one post, even under different subject lines, the forum moderator will remove one (or more) of the redundant posts.
MY QUESTION: What are the rules about simply posting a link to another forum like arduino.cc or should I recreate the post here?
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-12-22 10:14
    My guess is this is basically referring to multiple forums in the Parallax community.
    Since we have relatively modest overlap with the Arduino forums, it would be permitted in this case.
    Just my thoughts!
    Duane J
    edited 2012-12-22 10:16
    Hi Arduito - Welcome to the Forum, and thank you for checking about this.
    I read the guidelines as pertaining to this Parallax forum only.
    And to make sure you remain within those guidelines, recreate the post here.
    Ask away!
    edited 2012-12-22 10:27
    Arduito: Sure, we welcome you Arduino folks here, but noobs only get to ask one single question, so they must make it a very important one.
    Too bad you used yours up already:
    Arduito wrote: »
    Just kidding, thanks for asking and fire away with your questions!
    edited 2012-12-22 10:37
    ...hmmm, looking at the 2X16 LCD datasheet, I don't see how the requested time signatures can be generated.
    Although I wouldn't be surprised if there IS a way...
  • ArduitoArduito Posts: 4
    edited 2012-12-22 10:46
    OK, thanks everyone.
    I just posted it as a new thread with the subject:
    Parallax 2x16 Serial LCD Backlit, with Speaker #27977-RT
    edited 2012-12-22 10:50
    After posting, I got a quick screen. I couldn't read it fast enough. Since I don't see it posted, I'm assuming it has to be moderator approved first?
    Hi Arduito - yup. For some odd reason your post has been marked for moderation, and I don't know why.
    I think one of the Forum Gurus will have to address it as it's outside of my small moderator powers.
    ***Edit - ok, figured it out and you're good to go!
