Anyone seen these 3 legged voltage regulator drop-in replacements? — Parallax Forums
Don MDon M Posts: 1,653
edited 2012-12-22 04:04 in General Discussion
  • stamptrolstamptrol Posts: 1,731
    edited 2012-12-21 09:36
    Have used a similar product from a couple of manufacturers. This one is physically smaller and quite a bit cheaper.
    If your board needs more than, say, 300mA or so, these really keep heat dissipation under control.
    Cheers,
  • Martin HodgeMartin Hodge Posts: 1,246
    edited 2012-12-21 09:42
    I've been replacing every heat-belching 780x part I can find in my old equipment with these cool running, switching alternatives. Maybe they'd not be so good for audio equipment? But for everything else I haven't found a downside.
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-12-21 11:19
    The ripple/noise spec looks pretty decent for a switch mode regulator, I've seen much worse in some of those cheap bench-top power supplies you can find on eBay and elsewhere. The price is not bad either.
    Check out the 78E5.0 parts at digikey and mouser.
