Use BS2 to switch 12V circuit
I am using a K80 Power Supply Control to energize an electric latch (Adams Rite 7100-310-628.. 12V .332 amp.. but the K80 relay supplies this power) The Power supply control has a ground and a push connection used to connect a push button to and activate the lock. There is a 12V potential across the PUSH and GND, only a momentary connection is needed because the K80 has a timer built in to it that keeps the lock open as needed. Momentarily using a wire to connect PUSH and GND makes it work.. as does using a resistor. I have used a 4.7K.. it works but have to touch it just right or longer sometimes it seems.. a 2.2K resistor across PUSH and GND works great just by tapping the terminals.
Given these details.. is there a good safe way to switch this using my BS2 with either a 4N29SD Fairchild Opto or a radio shack transistor?
I've done several forum searches and read some Nuts and Volts articles but did not glean an answer I am confident with.
Thank you all for your input.
Daniel
Daniel
Since the switch activates using a 2.2K R, would it be a good idea to use one between 12V (Push) and collector.. then emitter to GND on the K80?
Thank you,
Daniel
Yes. A 2.2K should work fine. A 1K will do as well and anything in-between. This looks like a switch closure input (to ground) and probably has its own resistor internally. Use a 1/4W resistor if 1K.
