IR emitter reciever problems
![lardom](https://forums.parallax.com/uploads/userpics/734/nY2PNZOVLPMXD.jpg)
It is always harder than you think it is. I wanted to experiment with IR detection on the Propeller to test on a wall following robot. "Follow the schematic and run the program. Double check and rerun. Remove the resistor and rerun"...and so on. I'm stuck. I used a digital camera to see if the ir led was working and compared it to a TV remote control. It was faint but the schematic called for a 1K resistor. The remote control did cause the PST to change state. I need help.
![IR emitter and reciever.jpg](https://forums.parallax.com/uploads/attachments/55908/95018.jpg)
John Abshier
