P2: pin output question
 potatohead
potatohead
                    Here is a short program that writes the counter to some of the output pins with LED's attached on the DE2 board.  Edited because I pasted the wrong code.  Sorry.  Here are the correct programs:
What am I missing here? No combination of AND appeared to work for me. ??? I tried making the outmask value all ones too.
                            ' Terasic DE2-115 Prop2 LED Blinker
' This one is broken, and I don't know why
DAT
                org
                neg     dirb, #1        'make the port B I/Os outputs
:loop           getcnt  A               'fetch lower 32 bits of global counter
                shr     A, #16          'shift away the fast incrementing digits
                and     A, outmask      'zero lower bits
                mov     pinb, A         'write slow ones to LED's on DE2 board
                jmp     #:loop          'keep doing it!
A               res     1               'storage
B               res     1
outmask         long    $00_00_FF_00    'write higher bits only
' This one works!
DAT
                org
                shr     A, #24          'shift away the fast incrementing digits
                shl     A, #8
A               res     1               'storage
Why not use this that way
000011 001 1 CCCC nnnnnnnnn 011001010 SETF #n 'Configure field mover with 0..511 1 neg dirb, #1 'make the port B I/Os outputs SETF #XX 'Configure field mover with D 1 000101 000 0 CCCC DDDDDDDDD SSSSSSSSS MOVF D,S 'Move field from S into D 1 instead of shr A, #16 'shift away the fast incrementing digits and A, outmask 'zero lower bits mov pinb, A 'write slow ones to LED's on DE2 board
