Propeller/Spin and a RFM12B-S2 Wireless Transceiver
Been a while since I played around with my Propeller set. I have a project request from a friend that wants to build 2 wireless wristbands that can buss each other. I found the RFM12B-S2 Wireless Transceiver at https://www.sparkfun.com/products/9582 Has anyone here use this before? It says it support SIP. For a vibrator, I was going to use a coin vibrator motor.
Thoughts, suggestions or sample spin code on wireless communications?
-=Ryan
-=Ryan
Here's a place you can get ten of them for $15.57.
I have a driver to use the Nordic chips with the Propeller (see post #2 of my index). I have a faster version of the driver I keep meaning to post but I have to remove some project specific code from it first. One of the many things on my Propeller todo list is to get the Nordic driver working better and faster (it does work in its current form).
Hi ryman,
i used the democode from Marcello in my project and it works fine:
http://forums.parallax.com/showthread.php?117546-Anyone-interested-in-the-RFM12-Transceiver-Module/page2&highlight=RFM12
and here you can find a command calculator:
http://tools.jeelabs.org/rfm12b
