POLL- Suggest (5) objects the Prop needs to be seen as a viable alternative to — Parallax Forums
koehlerkoehler Posts: 598
edited 2012-12-21 11:14 in Propeller 1
the professional engineer in the industrial markets mentioned here: http://www.parallaxsemiconductor.com/corporate/aboutus
Note- This is a small attempt to get the Gold Standard Library going again. At this point we just want to get a count on objects.
1.
2.
3.
4.
5.
  • SRLMSRLM Posts: 5,045
    edited 2012-12-14 00:20
    My Opinion, in no particular order:
    1. FSRW
    2. FFDS1
    3. "All purpose I2C driver"
    4. The Wiznet Drivers
    5. 24 channel MCP3208 driver
    edited 2012-12-14 06:24
    koehler wrote: »
    1. template and example for a general serial driver
    2. template and example for a general I2C driver
    3. template and example for a general ADC driver
    4. template and example for a general DAC driver
    5. template and example for a general PWM driver
    These would include
    • an example of walking through the datasheet for a common part,
    • identifying the details that need particular consideration (and why as needed),
    • an example circuit,
    • code in spin,
    • steps for testing
    • expected results
    • example of good results
    • examples of errors/ debugging and the resolution
    • process for optimizing in assembler (or reason why this would be unnecessary)
    The idea being that armed with this information, most folks would be able to recognize and use the power of software programmable peripherals.
  • Brian FairchildBrian Fairchild Posts: 549
    edited 2012-12-14 07:47
    ...SNIP...
    All essential but they do fail to show just what the Prop is capable of.
    Anyone doing a side-by-side comparison of a Prop to A.N.Other uProc will struggle to a see why they should take a gamble on the Prop. As a comparison, for the same money and board area as a Prop, I can have a uP that has...
    3 x SPI
    5 x I2C
    6 x USART
    2 x CAN
    5 x PWM
    16 x 10-bit ADC
    5 x 16-bit timers
    2 x 32-bit timers
    1 x JTAG debug port
    plus loads more memory
    Having just 'single device per COG' Gold Standard peripherals will not show the Prop in a good light.
    edited 2012-12-14 07:56
    On P2, we have the threading, which can yield up to 32 hardware supported threads. Video, keyboard and mouse will be possible, for example. Right now, we have P1, and the multi-device per COG model is difficult, but it won't always be. Worth considering as this discussion progresses.
    edited 2012-12-14 08:07
    Question is, what is a Gold Standard intended to provide? Is is reliable software that can be use for a particular purpose, or another sales pitch?
    I think the former is what is needed (hnce the request for the Gold Standard), and the later exists in abundance or can be created custom for a specific audience.
  • Alex.StanfieldAlex.Stanfield Posts: 198
    edited 2012-12-14 08:37
    My Vote
    1. Universal and multiple Serial interface with API handling for XBee
    2. FSRW (ideally with clock reading from the RTC embedded in the PASM driver for speed)
    3. Universal I2C/SPI driver
    5. Universal ADC/DAC/PWM
    Some more to consider
    - Stepper Pulse Generator with ramping
    - Module and App Note on implementing speed control (with feedback) with the Pololu drivers
    - Skeleton and App Note on creating a Finite State Machine using multiple cogs. I believe the Propeller shines here given it's unique capability of true parallel processing of events.
    Alex
    edited 2012-12-14 09:22
    I said it elsewhere but for the purpose of promoting the Propellers in the commercial world as is the mission of Parallax Semiconductor:
    All Gold Standard objects must be written in C and/or PASM.
    And I also said elsewhere, let's not call them objects. Call them "modules" or "libraries". The word "object" has connotations of object oriented programming.
  • rod1963rod1963 Posts: 752
    edited 2012-12-14 09:35
    Not our business, it's Parallax's decision how to decide how to market or not market the Prop.
  • Ahle2Ahle2 Posts: 1,179
    edited 2012-12-14 12:32
    If you ask different Propeller users which objects they consider being "Gold Objects", they will most likely answer based on what they personally have come across when doing some specific projects with some specific requirements.
    They might have experience with 10 out of the 700++ objects in the OBEX.
    Those objects may not be
    * The best of its kind
    * Well written
    * Using the the "full" potential of the Propeller
    * General enough
    * Etc
    We need to have a better way of deciding which objects really are Gold standard. We need to filter out the most obvious garbage first!
    IMHO, in most cases pure spin objects goes directly in the garbage. Especially if performance is important.
    But of course there are exceptions where a pure spin object may be an advantage, e.g, when you don't want to "waste" a cog or when a small footprint is more important than performance.
    This is definitely not an easy task and I'm afraid that the real gold might be hard to find.
    Because of the reasons given above, I will not say my personal list of Gold Standard objects. (Yes I do have one)
    /Johannes
  • lonesocklonesock Posts: 917
    edited 2012-12-14 13:21
    Ahle2 wrote: »
    I agree with this 100%. For example, I use F32 when I need performance, otherwise the Spin-only FloatMath is perfect...cogs are often at a premium. It might be a good idea for each 'category' to have a candidate based on the number of cogs used. Having all with the same interface would be ideal. Video drivers, for example: 1 cog vs 2 vs 2, etc. If I had 3 cogs available, I would use 3, but if I have to downgrade the number of cogs, it would be great if I did not have to rewrite the interface.
    So, some kind of table:
        Function   |  0 cogs   |  1 cog  | 2 cogs  |  ...
    floating-point | FloatMath |  F32    |   N/A
    etc.
    Jonathan
  • koehlerkoehler Posts: 598
    edited 2012-12-15 18:44
    Johannes et al,
    Thanks for the input so far.
    As far as the comment that this is Parallax' responsibility, that is correct though short sighted.
    Parallax has obviously limited resources, and anything we can do can only help them when the final decision is made.
    Choosing not to help is your right, however not really of much help.
    Again as the subject was headed, this is a 'think outside the box' sort of question for many here, who are not professional engineers or developers.
    "Suggest (5) objects the Prop needs to be seen as a viable alternative to the professional engineer in the industrial markets mentioned here: http://www.parallaxsemiconductor.com/corporate/aboutus "
    Obviously the Prop has significant unique capabilities that are rather outside the norm, however it is the 'norm' that many are going to look to first to see if they want to expend any time to begin with.
    As an aside, Brian's comment on what he can do with one prop is a great primary demonstration head-turner that should be explored. Would be best if it actually used Gold Standard code.
    I agree and have mentioned before, the term objects is a poor choice and does infer something akin to OOP, which is not what I think many engineers want to even consider.
    That aside, what processing power would actually be available in Brian's demo unit once all those cores are used up running objects, modules, programmable hardware, etc?
    If there isn't much horsepower left, then it actually hurts more than it helps.
    edited 2012-12-18 19:52
    Hi All,
    So Thanks to the 3 people who took the time to post some suggestions, here are the results.
    Unfortunately, such a small sample does not yield 5 candidates.
    1. All purpose I2C driver
    2. FSRW
    3. Template and example for a general serial driver
    4. Universal ADC/DAC/PWM
    It doesn't appear as though the 'community' is really interested in doing much beyond either arguing about documentation or dissmissing any effort as Parallax's responsibility.
    So aside from you 3, and several other folks working on documentation, etc, I'm not sure what will come of this is anything.
    I'll PM Ken just so he can see whats been suggested, and maybe get a more sober view of how much support he can realistically expect to get.
    edited 2012-12-18 21:14
    Here is what Parallax want's Goldified:
    http://www.parallaxsemiconductor.com/support/goldstandard/commission
    ps to anybody reading this: I don't think the $50 credit is still available...
    edited 2012-12-18 22:27
    koehler wrote: »
    While my reply was primarily aimed at the implementation of your (very good) concept, I was also trying to implicitly recommend F32, but as it is my code I didn't want to come across as an egotistical jerk. [8^)
    Jonathan
    edited 2012-12-19 00:02
    SRLM, thanks I wasn't,t aware of the page.
    However, would appear as though it is an older page and PS doesn't even have 1 GSL yet?
    lone sock, understood.
    It was just rather annoying that with all the talk, and >250 views, only about 1% felt it worth input.
    Hopefully P-S has something planned for release time, as if not I think initial impression that will propagate for P2 is going to be 'faster Propeller, same lack of soft peripherals they are trying to sell on as before'.
    That seemed to be the general consensus of most of the professional types I heard after P1 had been out for a couple of years. Was hoping that can be avoided this time around.
    My concern is that the enthusiest niche has been Pic and AVR for a while now, with the Arduino the dominant force and growing. With the Arduino now getting into ARM, a lot of the straight horsepower advantage the P1 had is rapidly diminishing.
    I only can see the ARduino growing in popularity, even by people who have disdained it as a watered down platform. The power it will have with ARM is going to make it a seriously nontrivial competitor.
    For that reason, the P2 has to come out of the gate swinging, in both HW and SW/IP Blocks.
    I really hope Parallax has a plan.
  • KC_RobKC_Rob Posts: 465
    edited 2012-12-19 05:50
    koehler wrote: »
    Don't forget Raspberry Pi, which seems to be the darling right now, and other platforms that are here or on the way (mostly ARM based). I'm new to the Prop, so take what I say with a grain of salt. I do like the Prop and find it interesting, and the Spin tools make it easy to jump right in and start doing stuff - just to get familiar with the chip if nothing else. That said, I have yet to find a place for the Prop in one of my client's products/applications, in terms of cost, features, etc., in toto.
    Additional memory is one thing that is clearly needed (you'll see this mentioned over and over on forums where the Prop is being compared to other options). In terms of horsepower, it has enough for many applications but I see no overwhelming advantage there - yet. Having an extensive, ready-made library of modules/objects in place would certainly help Parallax market the Prop. Start with the basics (eg, serial interfaces) and go from there. Of course, nowadays file systems, networking, and so on fall more and more often into the "basics" category. Another thing the Prop has going for it is programming languages. It still compares favorably when you look at the number of programming languages that can be used on it. If I were Parallax, I would continue to encourage and explore different language options. More languages increases the market of potential Prop users, whether it be educators, hobbyists, or professionals.
    I probably didn't answer the question specifically enough, but I hope the two cents I've added here help.
    edited 2012-12-20 05:35
    A decent graphics library that is easy to use and well documented. Should include bounded area screen copies, text, fills and the works.
    Also, spin string handling needs to be much improved.
    Thirds, a standard sd driver and filesystem would be great.
    What is most important isn't having a lot of new objects, but having objects that are easy to use, nicely documented and work well.
    edited 2012-12-20 06:34
    lonesock wrote: »
    ... I didn't want to come across as an egotistical jerk.
    Don't worry, many off us are making efforts to cover this for you.
    koehler wrote: »
    You actually getting a fast response. My project thread has over 12,000 views, 400 comments, and 350 downloads (closer to 1000 downloads if you count previous version) and after almost 3 years we only have 10 team members.
    Some folks must lead, over folks must always follow. Some are shy, most are simply busy with other projects that have a higher priority.
    The power of soft peripherals is that we can do anything that we want. The "other edge of the blade" is that we must know something about what we want. The prop is just a little bit higher on the technology curve than most (hobbyist) folks think they can handle.
    Pic and AVR started as 8 bit, single thread, low MHz parts, that were simple to use. They are over powered for 90% of the "popular" apps that people use them for. Now they are getting bigger, so people can use them even less efficiently. We see a similar pattern as Windows PC. Now consider the prop is more than 10 times more powerful. People don't know what to think. Most folks can barely use 1 core.
    KC_Rob wrote: »
    Don't forget Raspberry Pi, .... Additional memory is one thing that is clearly needed (you'll see this mentioned over and over on forums where the Prop is being compared to other options).
    Prop and RPi are tools for completely different uses. RPi cannot handle realtime down to 12.5ns on multiple threads, Prop cannot handle processing large chunks of data or HD video. But if we let the prop handle the realtime, and the RPi handle the processing the large chunks of data (in a single thread) things work really nicely.
    Proper tool for the proper job. We can use a hammer on screws (the guys called using a hammer to drive drywall screws "Russian nails"), but its harder to use a screwdriver with nails.
    The biggest issue is there is a very broad and conflicting set of definitions for "nicely documented". And how to measure "nicely documented". On one extreme is the opinion that documentation should be measured in terms of requirements-tests-results; the other extreme says that is too excessive and they would prefer to take it on faith that a given code set "just works", and complain when things don't work out. On this point, the first step of defining what we mean is the most difficult.
  • David BuckleyDavid Buckley Posts: 12
    edited 2012-12-20 13:59
    [huge list of peripherals deleted]
    Yes, its all very well having all that stuff, but most projects only use a subset of that capability.
    But much more importantly: What makes the Prop worth the effort is the architecture, and even more so, what that architecture means to software development.
    It is so much faster to write an application that works rock solidly on a Prop (assuming the app will fit) than it is on the "other" chip because you can put something (and often that "something" is something from the Object Exchange) in a cog, and once its debugged and works, it just works. You dont need to service peripherals in main code or interrupts, and thats where much of the effort occurs in getting projects to work on the "other" processor. The time savings are enormous, and I'd suggest the reliability improvements are also important.
    The other problem with the Prop is Parallax. They make great stuff, but then either cut a corner, or wont hold faith waiting for folks to discover they have the perfect solution. For example, cancelling the spin stamp. And now I have another one. The GPS/Prop combo board is canned. Just when I thought I had found the perfect application for it. Or it would be an application if the 1 PPS pulse was available to the on-board Prop. But it seems it isn't. And on the surviving GPS module, the 1 PPS output from the chip also appears to be unavailable. Who would design a GPS solution, and then be so blinkered to think that no-one will ever need that useless 1 PPS output? Take gun, aim at foot, pull trigger.
    edited 2012-12-20 15:30
    I understand the part about right tool for the right job. But why a Prop, realtime or no? I mean why not another ARM (they come in all sizes now), AVR, PIC, or 8051. Or, depending on what the appication is, an FPGA? Or a DSP? Also, there's the educational market, which I believe has in the past been a good source of business for Parallax. With RPi, Arduino, Netduino, and all the rest... where does that leave room for the Prop? These are valid questions; I know from my own research into and consideration of where a Prop might make sense. Nor is any of this meant as a knock on the Propeller, which does in the end standout as something different altogether.
    Some of it may just be a matter of marketing. But it helps to know exactly where/what your market is, and once you do know, to make certain your product is ready for it.
    edited 2012-12-20 15:51
    KC_Rob,
    You can't just say, "real-time or no". If you need to do a bunch of real time stuff then a Prop might do it but an ARM, especially in a Raspi or Arduino will not. If you like to quickly build a real-time program incorporating work that others have done you can do it with Spin objects and COGs (or even in C now a days) not so easy on an ARM having to hook into interrupts and check how the timing of one part will effect the others.
    Conversely of course if you want a serious networking stack and other large scale things then an ARM is probably the way to go.
    It's is a big bonus to have a stock of Propellers, with no dedicated hardware peripherals, that can be adapted to different tasks as and when required over having to find a different version of AVR, ARM whatever with the right mix of peripherals for each job
    That's why I fascinated by the idea of pairing a Propeller with a Raspberry Pi, on a stackable board of the same form factor. They compliment each other rather than compete.
    From an educational perspective, what could be better than the elegant simplicity of the Propeller for learning assembler for example. It's about the simplest most regular, easy to use instruction set I have ever seen. Much more approachable than ARM.
    FPGA's are great, but up against Raspi, Arduino, Propeller they are a lot more expensive and much harder to use.
  • KeithEKeithE Posts: 957
    edited 2012-12-20 16:36
    For a project at work which is low volume (maybe thousands of units) the two important objects would have been:
    (1) full duplex serial, with support for hardware flow control (CTS/RTS), in-band flow control (XON/XOFF - not what level escaping/deescaping would be handled), automatic baud rate matching (e.g. sync to 0x80 or perhaps a character such as @), and baud rates up to 3 Mbit (perhaps 1 MBit would be sufficient).
    (2) I2C master at 400 kHz. Pretty plain vanilla but would be nice to make 10-bit slaves trivial to support. Perhaps the I2C master could respond to a device interrupt, although this might be handled at a different level.
    The characteristics of these interfaces would have to be well understood. e.g. how much jitter does the UART generate/tolerate, and does the I2C master meet the NXP specs.
    And supporting these from C would have been a big plus since that's how most development is done. It's too late for this project because they went with an Atmel processor, but I think that the Prop would have worked out nicely. The application is somewhat like a sensor hub.
    One concern would be Parallax Semiconductor's ability to respond to inquiries from the QA departments at large companies. Hopefully for this market it wouldn't be an issue.
    edited 2012-12-20 16:43
    Heater. wrote: »
    KC_Rob,
    Here we're not talking about just dropping an RPi or Arduino into something (at least I didn't take it that way), rather a design from ground up for a commercial or an industrial product. The uP/uC handling the offloaded stuff can be just the size needed to do what is required. There are plenty to choose from, other than ARM, in all sizes and architectures.
    Myself, I usually think of things like Arduino or RPi as educational tools, hobbyist toys, and platforms that are sometimes used to do prototypes for proof-of-concept. They may also end up from time to time in higher-end, low-volume equipment or designs strictly for in-house use.
    I can also do it with the many many libraries available, open-source and those provided by manufacturers. Never mind, too, that some of these things may be incorporated in onboard peripherals. So, yes, it can be done easily enough - and in fact is all the time.
    It's is a big bonus to have a stock of Propellers, with no dedicated hardware peripherals, that can be adapted to different tasks as and when required over having to find a different version of AVR, ARM whatever with the right mix of peripherals for each job.
    Agreed. Nonetheless, moving from one device to another in the same family can keep things fairly simple. So, for example, if your shop uses AVRs, there are plenty to choose from for most any job, and the tools stay the same and much of your in-house code ports seemlessly.
    I'd also be curious to see how that works out.
    Again, I don't disagree. But you'll have to sell them on it and, like it or not, competition in that space is fierce right now.
    It just depends on the application, right tool for the right job and all that. :)
    edited 2012-12-20 17:13
    Can't argue with any of that. An engineer will size up the job, both technically and economically, and use the appropriate parts.
    Except the part about the "..many libraries available...". It matters not what libraries are available, if you have a single CPU the use of some functionality from some library will impact the speed and timing of functionality from another library. There is no way around that. If you want to mix and match these things in your app you always have to take time into account. With the Prop it's not just that it's very easy to use Spin objects but that having 8 cores available to run them on you know that they are not going to have bad timing interactions. They will just work.
    I hate to mention it but as far as I know XMOS is the only other MCU vendor that has taken this approach, for the same reasons. However multi-cores have become all the rage recently.
    A Prop for your Raspberry Pi makes a very nice I/O expander if nothing else. Also it would be neat to make a VGA text terminal for the Pi. Besides we can now use the Pi to develop Prop code on using propgcc and SimpleIDE. No more PC required.
    edited 2012-12-20 17:25
    Heater. wrote: »
    I don't know that I'd go quite that far :) but yes, I see your point. As I readily admit, the Prop is a different approach altogether, one not without advantages. Which is why I remain so interested in it.
    edited 2012-12-20 17:36
    What I meant by "It matters not what libraries are available..." is that you cannot run more than one thing at a time on a single core MCU. Things like interrupts may help make it look like yo can, especially with an RTOS thrown in, up to a point. There is no way to get around the fact that one function can and will affect the timing of another.
    The only way around that physical reality is to off load functionality into more hardware that can operate in parallel. That can be hardware peripheral devices or the "more cores and do it in software" approach of Parallax and XMOS. Hardware peripherals are fine and cheap for standard functionality like UARTS, I2C etc etc but ridged, inflexible. The "soft peripherals" are fine for that not so standard stuff and for flexibility.
  • StephenMooreStephenMoore Posts: 188
    edited 2012-12-20 17:50
    Despite the fact that the P2 is looming, and I look forward to it, I have barely begun to tap the potential of the P1 in industrial control. The model of adding code functionally by COG so greatly simplifies system development I have become a firm believer. I do not need to worry the task interrupt priority issues of a long single threaded uP program with all of its arcane overhead that goes with it. Simply add another Prop and you've expanded the hardware interface accordingly. I really love it. Real time becomes truly real time control.
    Here is my list for machine control:
    1) Multiple serial interface
    2) SD (FSRW)
    3) SPI/I2C/One Wire
    4) Floating point
    5) Frequency synthesis (for a variety of PWM/stepper/inverter situations)
    6) VGA/KBD
    Just because the poll seemed meager is no reason to end the survey.
    sm
    edited 2012-12-20 18:19
    Heater. wrote: »
    The only way around that physical reality is ...
    Or simply run at a clock high enough that timing becomes a non-factor. I can do quite a bit with, say, a 100 MIPS 8051 which has several serial interfaces and analog peripherals to boot (eg, SiLabs C8051F120, under $10 I think). Usually when I'm off-loading stuff it's only two or three things anyway. Again, I am aware of the advantages a Prop might offer in that area (sort of a "soft" FPGA). So in that respect, I see your point and agree 100%. It depends on the application. I haven't found one yet, or at least not one I can sell a client on, but clearly they're out there.
    edited 2012-12-20 18:31
    From a purely logical point of view any amount of code that can be run in parallel can also be run sequentially, given a fast enough device.
    Perhaps, dare I say, the Prop I was only the prototype. It has the philosophy and architecture but perhaps enough limitations, memory, speed, to make it not quite viable in a broad range of industrial applications.
    We might hope the Prop II has enough chops to encompass more of that landscape.
    Anyway, there would certainly be no point in Parallax having built a more "normal" AVR, ARM, whatever style device, The world is swimming in those already.
    edited 2012-12-20 18:50
    Heater. wrote: »
    We're on the same page there, too. It would have been a HUGE mistake, in my view, for Parallax to have tried to make the PropII more like what is easily found in an already very crowded field.
