Need help using an ADC0831 and the SHIFTIN line in pBasic
Hello everyone,
I'm working on a project for school and part of it requires us to use a photo resistor to measure the amount of light in a room. I need to use the voltage read from the resistor to compare to a value from another photo resistor in a different room. The difference between the two will be used in an equation to control a servo. As most of us already know, the voltage read from the photoresistor is analog and therefore I need to convert it to a digital value seeing as how the Basic Stamp does not have a built-in ADC. We were instructed to use an ADC0831.
Can someone sum up how to use the SHIFTIN line in pBasic? I've seen the MSBPOST line/command used in conjunction with SHIFTIN here: http://www.parallax.com/dl/docs/prod/acc/SharpGP2D12Snrs.pdf and was wondering how exactly it's used.
I THINK this is how it works, and PLEASE correct me where I'm wrong
SHIFTIN AdcData, AdcClock, MSBPOST, [result\9]
AdcData - designates which pin will be used for as the data input
AdcClock, designates which pin will used as the clock output to the ADC0831
MSBPOST - ?????
[result\9] - stores digital value to 'result' not too sure about '\9'
Please help, I'm starting to get desperate.
Thanks in advance!
' ========================================================================= ' File...... GP2D12 Demo.bs2 ' Purpose... Demonstrate GP2D12 ' Author.... Parallax, Inc. ' E-mail.... support@parallax.com ' {$STAMP BS2} ' {$PBASIC 2.5} ' ========================================================================= ' -----[ Program Description ]--------------------------------------------- ' This program demonstrates reading the distance in centimeters from the ' Sharp GP2D12 Analog Distance Sensor. ' -----[ I/O Definitions ]------------------------------------------------- Adc0831 PIN 0 ' ADC0831 Chip Select (ADC0831.1) AdcClock PIN 1 ' ADC0831 Clock (ADC0831.7) AdcData PIN 2 ' ADC0831 Data (ADC0831.6) ' -----[ Constants ]------------------------------------------------------- span CON 5 ' 5 cm Per Data Point ' -----[ Variables ]------------------------------------------------------- result VAR Byte ' ADC8031 Result volts VAR Word ' Volts (0.01 Increments) cm VAR Byte ' centimeters index VAR Nib test1 VAR Byte ' Values For test2 VAR Byte ' Interpolation slope VAR Word ' mV/cm between test points ' -----[ EEPROM Data ]----------------------------------------------------- Vout DATA 251, 179, 139, 114, 97 DATA 85, 76, 67, 62, 57 DATA 53, 50, 48, 46, 43 DATA 0 ' -----[ Initialization ]-------------------------------------------------- HIGH Adc0831 ' Disable ADC0831 ' -----[ Program Code ]---------------------------------------------------- DO GOSUB Read_GP2D12 ' Read Sensor Value GOSUB Calculate_Distance ' Convert Value To cm DEBUG HOME, "Distance = ", DEC cm, " cm " PAUSE 100 LOOP END ' -----[ Subroutines ]----------------------------------------------------- Read_GP2D12: volts = 0 ' Reset Sensor Value FOR index = 0 TO 2 ' Read 3 Times LOW Adc0831 ' Enable ADC0831 SHIFTIN AdcData, AdcClock, MSBPOST, [result\9] ' Read The Voltage HIGH Adc0831 ' Disable ADC0831 volts = volts + result ' Add The Values PAUSE 30 NEXT volts = volts / 3 ' Average The Readings RETURN Calculate_Distance: FOR index = 0 TO 15 ' Search DATA Table For Value READ (Vout + index), test2 ' Get Value From DATA Table IF (test2 <= volts) THEN EXIT ' Found Value NEXT SELECT index CASE 0 cm = 10 ' Set To Minimum Distance CASE 1 TO 14 ' Calculate Distance cm = 10 + (5 * index) IF (test2 < volts) THEN ' Estimate Using Interpolation READ (Vout + index - 1), test1 slope = (test1 - test2) * 10 / span ' Calculate Slope cm = cm - ((volts - test2) * 10 / slope) ENDIF CASE 15 cm = 80 ' Set To Maximum Distance ENDSELECT RETURN
MSBPOST - ?????
Thanks in advance!
The same writeup explains the '\9' and has to do with how many bits are produced by the ADC0831. You might look at the datasheet for the ADC0831 (do a web search). This has some nice pictures of the relationship between the clock pulses and the data and what is contained in the data bits.
First and foremost I would like to thank you for your quick and detailed response. Next, I would like to apologize for my confusion. Looking up SHIFTIN in the Syntax manual explained everything pretty clearly. It's amazing how much things make sense when you click on the right thing you want to learn.......I accidentally clicked something other than SHIFTIN and in my confusion and desperation I didn't realize and just became even more confused
Thanks a bunch Mr. Green!
For examples let's say I have two variables both with binary number 1010 stored to them from my SHIFTIN command (I believe if I were to type it in it would have to be %1010). If I wanted to add them and then take 60% of them could I write the following?
(var1+var2)*(3/5)
So, yes, you can take the number received from the ADC0831 and do any kind of arithmetic on it. Do remember that there are no decimal fractions, so (var1+var2)*(3/5) won't produce what you might want. You'll get more like what you want if you write ((var1+var2)*3)/5.
