Broadcasting on VHF
Ok so a while ago I did this fairly simple tutorial at gadget gangster showing you how to use the TV driver to brodcast video. Today I picked up some sony watchman portable TV (black and white
but you cant beat 2 dollars) I got it specifically to use for a wireless screen for my robot, I figured it would be cool to be able to see graphical representations of the lidar/sonar and read statistics like speed.
Anyways I dont know anything about RF, at the end of the tutorial at GG it says you can brodcast and revive data on the video generators. Im curious what kind of bandwith could you get doing this? Would this be a good way to do wireless serial, Im sure with some antennas you could get good range, maybe 50ft or so? Could you brodcast video and data at the same time maybe of different channels? What is the legality of this?
http://forums.parallax.com/showthread.php?140886
Maybe im confused I thought that book programming and customizing the propeller had something in it about wirelessly broadcasting to a TV. The more I look at some of these projects online they are just sending data via an xbee or some other means from a propeller to a propeller actually connected to a TV which then does the rendering. Is this the same technique used in the book mentioned above? I had hooked this all up before, with a regular TV, and got a decent signal just using wires for antennas and thought it could be a whole bunch better with decent antennas, sad this isnt this case. Acually broadcasting wireless TV from a robot would be pretty cool.
You can always use an xBee or WiFly module to transmit the data to a computer to overlay on a video feed. A data channel like that could handle a series of still images or low resolution video, but you need a video transmitter to send full resolution full speed images in real time.
