Power supply filtering question
I have been reading about building power supplies lately and I came across this paragraph,
"It should be obvious that the smaller the XC of the filter capacitor in respect to the load resistance, the better the filtering action. By using the largest possible capacitor, we achieve the best filtering. The load
resistance is also an important consideration. If load resistance is made small, the load current increases,
and the average value of output voltage (Eavg) decreases"
So, this suggests just taking the largest cap I have available and use it to filter with ?? That doesn't sound correct to me for some reason.
Go here:
http://www.onsemi.com/PowerSolutions/supportDoc.do?type=manuals
and download the "Linear and Switching Regulator Handbook". It describes how the amount of filtering is defined for a given ripple voltage.
^ That was a joke btw ;x
linear. ( have not got to the part about regulators yet...)
Here is a decent example:
http://pminmo.com/simple-power-supply
You may also want to read this:
http://www.kpsec.freeuk.com/powersup.htm
