Am I blind or does this part not exist? — Parallax Forums
edited 2012-12-12 16:52 in General Discussion
I'm looking at a device which is controlled by a variable resistor.
Is there a micro-controllable device which the variable resistor can be replaced?
Ether this part doesn't exist, or I'm just really blind.
Which is it?
Thanks!
Jeff
  • eldonb46eldonb46 Posts: 70
    edited 2012-12-12 12:33
    What do you want to control with your variable resistor, what voltage, current and frequency?
    I have successfully used the I2C controlled MCP4441 and MCP4018 in my Prop projects.
    Eldon
  • TubularTubular Posts: 4,774
    edited 2012-12-12 12:38
    motorized pots
    digital pot ICs
    For the digital pots you need to understand a little bit about the circuit, to know what voltage is being applied to the ends of the existing pot for instance. Some of the analog devices pots have a wider voltage range on the ends of the resistor, eg +/- 12v.
    edited 2012-12-12 15:14
    Thank you for the links! (and expanding my knowledge a little more today.)
    Exactly what I was looking for..
    Jeff
  • W9GFOW9GFO Posts: 4,010
    Keep in mind that most digital pots can handle only a teeny bit of current.
