Help writing eeprom upper 32K
lardom
My object successfully writes to and reads from the lower 32K of my eeprom. I thought adding "+ $8000" would create an automatic offset moving the variable into a predictable location in the upper 32K. The following code does not work.
Ex:
Having to address memory with hex would be a drag.
Ex:
[SIZE=3]PUB Backup_element(idx)
eeprom.VarBackup(@Y[idx], @Y[idx] [COLOR="#A52A2A"]+ $8000[/COLOR]) [/SIZE]
With BASIC_I2C_DRIVER version 1.3, the call would be,
i2c.writebyte(i2c#BOOTPIN, i2c#EEPROM, address, value)
and the address in the upper 32k would indeed be +$8000. That passes the value, so if you want to do it by address, it would be byte[@lowAddress].
If you modify the program in lower EEPROM at all the variables will likely be in a different location so you'd no longer be able to find the previously saved variables.
Which board are you using? Some early QuickStart boards only had 64K EEPROM. Post #24 of of this thread has a program that will tell you if you have a 32K or 64K EEPROM. The part of the program that tells you the size of the EEPROM works but the rest of the program is very buggy so don't use it as a reference on how access EEPROM.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ Menu : "Menu" eeprom : "Propeller Eeprom" VAR byte Y[5], cog long stack[5] PUB main Menu.Init Add_value PUB Init : success Stop success := (cog := cognew(Add_value, @stack)) + 1 PUB Stop if cog cogstop (cog~ - 1) PUB Add_value 'Displays values in "Y" array Load repeat Menu.DisplayElement(Y[0], 0) 'need index Menu.DisplayElement(Y[1], 1) Menu.DisplayElement(Y[2], 2) Menu.DisplayElement(Y[3], 3) Menu.DisplayElement(Y[4], 4) Menu.GetElement(0) ' Wait for user input Save_It(7) 'Random value for testing purposes [B]PUB Save_It(x) : idx [/B] repeat ' scan for free slot ifnot Y[idx] ' use local idx Y[idx] := x ' found free (==0) quit loop [B]Backup_element(idx)[/B] quit ' update global index and store value idx++ if idx > 4 ' If array full, bytefill(@Y[0], 0, 5) ' reset, array and idx (start addr, value, count) Y[0] := x [B]Backup_array[/B] PUB Backup_element(idx) eeprom.VarBackup(@Y[idx], @Y[idx]) '+ $8000 PUB Backup_array '' Back up entire array to EEPROM eeprom.VarBackup(@Y, @Y[4]) ' Copy Y array from RAM to EEPROM PUB Load '' Load entire array from EEPROM eeprom.VarRestore(@Y, @Y[4]) ' Copy array from EEPROM to RAMI get my intended results after a reset. It still needs work. I'm going to use this to save 'speed' and 'distance' settings.
@Tracy Allen, I found "BASIC_I2C_DRIVER version 1.3" I'll study it and try to apply what you've said.
Hence, after booting the HUB-RAM is an exact copy of the first 32k of the EEPROM. So, each variable has the same address in HUB-RAM than in EEPROM. With backup you simply give a start- and end-address of what you want to save to the exact same location in EEPROM. That's why you only need 2 parameters. If you'd have a free save to EEPROM function, then you'd need 3 parameters:
1. source address
2. destination address
3. number of bytes to copy.
Again .. this is what I see reading your code not knowing "Propeller Eeprom". Maybe I am wrong.
Did you check the sizes of your EEPROMs?
The Demo Board only has 32K. Some QuickStarts also only have 32K,
When I use the "PropellerEeprom" object, I only use "ToRam" and "FromRam" since it lets you read or wrtie multiple bytes at a time.
I think you were using the method "VarBackup" incorrectly (in your top post). The "+ $8000" was causing 32K of hub ram (and one byte of ROM) to be copied to EEPROM. On the demo board you were just writing over the top of the original EEPROM with just about (except for changed variables) data.
If your EEPROM is only 32K, Whatever addresses you use above $7FFF are treated as if they were the address minus $8000.
I think below is what you intended for your "Backup_element" method.
PUB Backup_element(idx) eeprom.FromRam(@Y[idx], @Y[idx], @Y[idx] + $8000) 'save single byte to upper EEPROMBut again, this would only work with 64K EEPROMs. On 32K EEPROMs the above code would just write to "@Y[ind]".
It's hard to know what your code is really doing since you reference unknown (to us) object(s).
@Duane Degn, According to the Quickstart package specs the eeprom is 64K. I'm going to test your code and if it works I'll have to study it closely. It takes a while for stuff to sink in.
If you have a relatively new QuickStart if should have 64K. The very first ones made had 32K. Parallax would replace the 32K versions with 64K units if you gave your 32K QS to someone who hadn't used the Propeller before. I had purchased four of the 32K QS boards. It was easy to find four people who hadn't used the Propeller and wanted to try it.
I have many more than the original four now.
I'm not a teacher now. I did teach high school chemistry and physics before my heart-transplant.
Let's say you have a variable var[10] in HUB-RAM. The backup( @var, @var[10] ) will simply copy the whole array to the same address in EEPROM that it has in RAM. I other words it really expects 2 RAM-addresses as parameter. This is why an offset of $8000 does not work!
If you want to implement wear-leveling and storage in upper EEPROM you need the FromRam and ToRam functions. And you need to be aware of the EEPROM pagesize. An EEPROM always writes full pages even if you only changed a byte. A strategy depends on what data you write. Can the data have any value or can you use a dedicated value to mark unused EEPROM space? Or can you efford some overhead which contains a counter? The highest value of a counter-location will then tell you where the actual data is stored.
@Duane Degn, Do you have an idea what percentage of your students continued to study science?
Do you have a need for SD card in this project? They do wear-leveling themselves.
Most of my program that write to EEPROM only do so a few times a day. I figure at a couple of writes a day it will take a long time to wear out my EEPROMs.
I remember from writing a driver for some Winbond flash chips, that I had to erase a whole page of memory before writing to the memory. If I wanted to edit a portion of memory, I had to first save the page into hub RAM and then erase the page and write back the entire page with the edited data. I don't take any of these precautions with EEPROM and I haven't noticed any problems.
Should I be concerned about writing across page boundaries on an EEPROM if I'm only doing so a few times a day?
As you suggest, I use a SD card for most of my Propeller data storage needs.
@Larry, I'm not in contact with many of my previous students (it's been about twenty years since I've taught at high school). The few I do know (from being friends of their family) did not pursue a science eduation. I enjoyed teaching immensely; I really enjoyed the students and it was a lot of fun doing demonstrations for the classes.
and Acknowledge polling can provide significant time
savings. Writing 128 bytes to the 24LC512 via byte
writes at 400 kHz requires roughly 652 ms worst-case.
Switching to Acknowledge polling brings that down to
roughly 396 ms (assuming typical conditions), nearly a
40% decrease. Additionally, changing to page writes
further lowers the time to an impressive 5.95 ms, a
decrease of over 98%. Overall, the two techniques
provide a combined time savings of nearly 646 ms,
increasing the total data throughput a staggering 109
times over."
That is what microchip say about their devices.
So, there are 2 modes of writing to an EEPROM. If the driver you use sends the data byte by byte writing to the EEPROM needs much longer, as after each byte you have to wait for the EEPROM to finish programming. If the driver uses page mode but your code is doing byte-write in random fashion (writing 2 bytes to address x, then some bytes to address y where y>x+page size and then goes back to write something in x+2 again), then the EEPROM will in fact wear out earlier.
What I understand is, that lardom want's to take care of the wear leveling to maximize the lifetime of the EEPROM. So, if he writes things in page mode he has to be aware of the fact that he is wearing out the whole page in this case.
Having a look at the used driver, you'll see that Propeller EEPROM.spin is really working in page-mode.
repeat page := addr+64-eeAddr//64<#endaddr+1 ' Find next EEPROM page boundary SetAddr(eeAddr) ' Give EEPROM starting address repeat ' Bytes -> EEPROM until page boundary SendByte(byte[addr++]) until addr == page i2cstop ' From 24LC256's page buffer -> EEPROM eeaddr := addr - startAddr + eeStart ' Next EEPROM starting address until addr > endAddr ' Quit when RAM index > end addressBasic I2C on the other hand has functions for writing in page mode and functions for writing in byte-mode. So, it's on your side to choose the right one.
@Duane Degn, I've written in a journal that if you can read a book you can learn in a short time what may have taken the author a lifetime to learn. Teaching is a noble profession. I'm still amazed at how quickly I've learned because of this forum.
I had looked at the object to see if I could find anything about using pages but I didn't see where pages were mentioned until seeing your post. I think I was expecting the page writes to be taken care of by one of the private, lower level methods. I really appreciate your pointing out the page write section of the code.
Atmel's datasheet gives the lifetime of their EEPROMs of one million write cycles. So I figure I can write to EEPROM 27 times a day for a hundred years before it wears out. Even if the limit were 100,000 write cycles, I don't think any of my projects use the EEPROM in a way such that I need to worry about wear leveling.
Thanks again for taking time to explain this concept so well.
@Larry, I'm constantly amazed how many people generously help strangers to learn things. I think it's amazing the way we humans are so willing to pass on information we've learned.
That is how I finally wrapped my head around how to read and write above 32K. All of the explanations I had read made sense in my head, but not on the Prop until I tried doing it for myself with a 128K EEPROM. Then it became clear, my head was the problem.
I am so sorry I missed your question... Holidays began early with in-laws moving in for a month.
This is the one I was talking about http://obex.parallax.com/objects/612/
I hope this helps if you still need it.
