Dual ping sensor navigation — Parallax Forums
knd775knd775 Posts: 2
edited 2012-12-11 20:01 in Learn with BlocklyProp
I am using two ping sensors, one mounted on the front and one mounted on the left, to navigate around a box, walled with 2x4s, and pick up 12 golf balls in predefined locations. I am having problems writing the code to keep it a set distance (24cm) from the wall on the left. Theoretically, this should work, I think, but I don't know quite enough about PBasic to know if everything I am doing is correct/ possible.Here is what I have at the moment:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Team QuickPick
' Code by ----- -------
pulseCount   VAR     Byte
runNumber    VAR     Byte
correctPulses  VAR  Byte
'angleResult    VAR  Byte
CmConstant   CON     2260
InConstant   CON     890
cmDistanceFront   VAR     Word
inDistanceFront   VAR     Word
timeFront         VAR     Word
cmDistanceSide  VAR     Word
inDistanceSide  VAR     Word
timeSide        VAR     Word
FREQOUT 11, 125, 5000                        ' Signal program start/reset with piezo buzzer.
PAUSE 1500
DO
  runNumber = runNumber + 1                  ' Adds 1 to "runNumber" counter
  GOSUB forwardUntilWall
  GOSUB turnRight
  LOOP UNTIL runNumber = 99                  ' Loops so that program runs X number of times
END
'[Sub-Routines]
forward:                                     ' Forward subroutine.
  FOR pulseCount = 1 TO 122
    PULSOUT 13, 850
    PULSOUT 12, 650
    PAUSE 20
  NEXT
  RETURN
forwardUntilWall:                            ' Forward with ping))) subroutine.
  DO
  GOSUB checkDistanceFront
  PAUSE 20
  GOSUB checkDistanceSide
  IF cmDistanceFront < 36 THEN
    RETURN
  ELSEIF (cmDistanceSide >= 24) OR (cmDistanceSide <= 26) THEN
    GOSUB correctDirection
  ELSEIF cmDistanceFront > 36 THEN
    PULSOUT 13, 850
    PULSOUT 12, 650
  ENDIF
  LOOP
  RETURN
backward:                                    ' Backward subroutine.
    PULSOUT 13, 650
    PULSOUT 12, 850
    PAUSE 20
  NEXT
  RETURN
turnLeft:                                    ' Left turn subroutine.
  FOR pulseCount = 1 TO 29
    PULSOUT 13, 650
    PULSOUT 12, 650
    PAUSE 20
  NEXT
  RETURN
turnRight:                                   ' right turn subroutine.
    PULSOUT 13, 850
    PULSOUT 12, 850
    PAUSE 20
  NEXT
  RETURN
checkDistanceFront:
  PULSOUT 10, 5
  PULSIN 10, 1, timeFront
  cmDistanceFront = cmConstant ** timeFront
  inDistanceFront = inConstant ** timeFront
  DEBUG HOME, DEC3 cmDistanceFront, " cm (front)"
  DEBUG CR, DEC3 inDistanceFront, " in"
  RETURN
checkDistanceSide:
  PULSOUT 9, 5
  PULSIN 9, 1, timeSide
  cmDistanceSide = cmConstant ** timeSide
  inDistanceSide = inConstant ** timeSide
  DEBUG HOME, DEC3 cmDistanceSide, " cm (side)"
  DEBUG CR, DEC3 inDistanceSide, " in"
  RETURN
correctDirection:
  IF ((cmDistanceSide - 25) > 0) THEN
    'angleResult = ((inDistanceSide - 10) /
      PULSOUT 13, 850
      PULSOUT 12, 850
      PAUSE 20
    NEXT
  ELSEIF ((cmDistanceSide - 25) < 0) THEN
      PULSOUT 13, 650
      PULSOUT 12, 650
      PAUSE 20
    NEXT
  ENDIF
Any help would be greatly appreciated.
    edited 2012-12-07 13:20
    Is this for a BoeBot?
  • knd775knd775 Posts: 2
    Yes, it is. I apologize for not replying sooner. My notification settings are weird...
