Soldering SMT parts — Parallax Forums
Soldering SMT parts
4x5n4x5n Posts: 748
edited 2012-12-13 19:42 in Robotics
I've decided that it's time for me to learn how to work with SMT parts on circuit boards of my design. I'm thinking that with a bit of practice I can get PC boards designed with diptrace and have found a few places that make PC boards. My problems are many. The first is that I don't know what it is that the board makers will need to make the boards. I'm sure that a phone call to the pc board jobers will give me that info thogh so I'm not all that concerned.
What's got me scared is soldering the parts to the board. I've been looking at boards that have a prop, usb/serial converter soldered onto it and I have to admit that at my age my eyes aren't good enough to have a chance of getting the chip onto the pads of a board and touching each pin with a soldering iron without making a mess.
My question for those that work with smt boards is how do you place the parts onto the board and solder them into place. Any information would be greatly appreciated. If you live in the Chicago area I'd gladly pay for hands on help.
    edited 2012-12-05 17:52
    4x5n wrote: »
    I've decided that it's time for me to learn how to work with SMT parts on circuit boards of my design.....
    I've not yet got started on this SMT thing myself, but there's been lots of good info on the forum for procedures involving toaster ovens, etc. Have you seen any of these:
    http://forums.parallax.com/showthread.php?130196-How-I-do-SMT-soldering-in-toaster-oven
    http://forums.parallax.com/showthread.php?128554-Soldering-Surface-Mount-Devices-at-Home
  • 4x5n4x5n Posts: 748
    edited 2012-12-05 18:54
    I've seen those sites and you're right they have a lot of good information in them. They in fact convinced me that it's possible for me to work with surface mount parts. Sadly the links to toaster ovens, controllers, etc are old and don't work. I've looked around and found hot air systems at a price that I'm willing to pay. My biggest current problem is how do people actually see what they're doing and align the chips. those 44 - 48 pin chips are tiny!!
  • LeonLeon Posts: 7,620
    edited 2012-12-05 19:17
    I use a stereo dissecting microscope.
  • SRLMSRLM Posts: 5,045
    edited 2012-12-05 20:15
    I use tweezers to place the parts, a Zephyrtronics syringe for the solder, and a toaster oven for the parts. To inspect I use various magnifying glasses, and to touch up I use solder braid, flux, and a soldering iron.
    As a rough rule of thumb, you can get 15% positional error on your placement, and the surface tension of the solder will move it into place.
  • tonyp12tonyp12 Posts: 1,951
    edited 2012-12-06 10:41
    I do just like SRLM, after a year getting 95% sucess rate.
    I use a regular handheld magnifying glass, as I can move my head,hand and PCB to get that extra magnification but still keep it in focus.
    Sometimes I put on too much solder paste and have to use flux w braid to remove solder on bridged pins.
    And I also use Hot Air SMD Desoldering Station to complete lift the IC off the board and start over on that part or at least nudge it in place.
    edited 2012-12-06 12:59
    tonyp12 wrote: »
    Any thoughts on the type of toaster oven to get? I've seen references to model numbers but every time I check that model turns out to have been discontinued. Is there anything to watch out for when choosing an oven? I've also seen reasonably priced hot air smd stations and was thinking about using it to solder the parts instead of a toaster oven. Is that a good choice? My thinking was to use a magnifying lens to place the part with tweezers and then while holding in place solder it quickly with the hot air.
    edited 2012-12-06 13:07
    Another popular soldering technique is "drag-soldering". The chip is tacked down by soldering two opposite corners, then each row of leads is fluxed, and then soldered by dragging a special mini-hoof tip loaded with a small amount of solder along the row. Metcal makes suitable mini-hoof cartridges for use with their soldering systems, like the MX-500 handpiece that I use with an STSS power unit.
    edited 2012-12-06 19:48
    4x5n wrote: »
    I would go for the oven instead of the hot air station (if you have to choose one). The oven has the following advantages:
    1) It's faster: a complete board takes about 10 minutes total to cycle
    2) You don't have to worry about moving the part (hot air stations may "blast" the part away if you're not careful)
    3) You can do multiples at once
    4) If you need to replace a specific part, simply heat it up in the oven and pull it off with tweezers when hot.*
    5) You can do multiple boards at once.
    6) You have more precise temperature control.
    * Cycling the board too many times isn't good either. But a few is Ok.
    Of course, if you get both an oven and hot air reword station that's even better.
    I use this toaster oven. It heats up quickly and evenly, and is big enough to do many boards at once http://www.amazon.com/gp/product/B001L5TVGW/ref=oh_details_o00_s00_i00
    edited 2012-12-06 20:10
    Cody,
    That looks like a really nice oven. I can't tell from the Amazon site, though: are the time and temp dials encoders that produce digital steps, or potentiometers? ('Too bad one of the presets isn't "PCB" ! :) )
    edited 2012-12-06 20:20
    @Phil
    The knobs are digital, and they are the kind the "click" when you rotate them. The one odd thing about the system is the step amount when you give fast rotations. Normally, when you rotate a knob fast it is slow for a little bit, then it starts taking bigger and bigger steps to get you there faster. But with this oven, it starts taking weird increments such as 6 or 13. It's awkward in a non-intuitive UI way.
    But that's ok, since for my lead free solder I just put the parts on the top rack and set it to bake for 2 minutes at 230C. When it's done I open the door.
    I selected that oven over other comparable 1800 watt convection ovens for two reasons: the quartz heating elements, and the digital controls. The first produces more even heat (I'm guessing), and with the second it should be easy(er) for me to drop in my own electronics if and when I need to.
    edited 2012-12-06 20:27
    SRLM wrote:
    ... for my lead free solder I just put the parts on the top rack and set it to bake for 2 minutes at 230C. When it's done I open the door.
    So you don't even bother with a preheat cycle to activate the flux before the "final melt?" That certainly simplifies things.
    The oven I currently use has digital temp control and quartz heating elements, but it lacks a convection fan. Consequently, I do not get even enough heating to do large boards.
    edited 2012-12-06 21:00
    Sort of. I try to follow the Kaester standard solder paste reflow profile, which has a maximum temperature of 208-230C at a maximum time of 5 minutes. The oven actually takes a bit longer than that to heat up from a cold start, so it seems to follow the "Lee" profile: http://kicthermal.com/paper-a-articles/273-optimizing-your-reflow-profile-for-maximum-productivity-and-profitability
    http://www.kester.com/LinkClick.aspx?fileticket=OUPpdDgnu4U%3D&tabid=181
    edited 2012-12-06 21:49
    Looks like I'm going to be buying myself an oven for christmas!
    Thanks everyone for you help. Now all need is a good and large magnifying lens. I have to admit I get the willies when I look at a board with a propeller and a usb/serial chip on it! I can barley see the pins let and can't imagine putting the chip in place. :frown: I'm thinking I'll need a 10x or 20x magnifying lens and when I'm trying to place the chips a shot or two to steady my nerves.
    edited 2012-12-06 22:36
    4x5n wrote: »
    At some point, when I get some more time, I want to build something like the LPKF ProtoPlace E manual pick and place machine:
    Basically, it has a vacuum pick and place and a nice work area with an adjustable hand rest. Unfortunately, it costs $1025. The Zephytronics vacuum is only $200, however, and I can build the rest of the PropPlace E assembly myself.
    edited 2012-12-07 00:00
    SRLM wrote:
    The Zephytronics vacuum is only $200, ...
    Precision tweezers: $2.52. :)
    Anyway, that's what I use, and I've never had a problem placing small parts with it. For parts that are too large for the tweezers, one of these works just fine:
  • LawsonLawson Posts: 870
    edited 2012-12-10 13:22
    Surprised nobody's mentioned the SparkFun tutorials http://www.sparkfun.com/tutorials/category/2 I do most of my surface mount assembly with a temperature controlled iron, tweezers, solder, and solder-wick. (a bottle of flux is nice for when the wick dries out) I've even pulled up a few IC using solder-wick, an exacto knife, and iron by bending the leads up one at a time.
    Lawson
    edited 2012-12-10 13:47
    You can also cut through the leads along one side, bend the chip up and cut through the remaining leads, then remove the lead ends from the pads one at a time.
    edited 2012-12-10 13:56
    Leon wrote:
    You can also cut through the leads along one side ...
    I've done this myself, but I don't like to. The reason is that the transverse force applied to the lead by the cutters transfers to the pad, possibly putting enough strain on it to delaminate it. (Think about what happens when you cut the end off of a piece of wire with side-cutters. The end flies away with considerable velocity.)
  • max72max72 Posts: 1,155
    edited 2012-12-11 13:54
    I used a regular oven and solder paste, but I had problems with the syringe and regulating the solder paste amount.
    With a metcal solder station I can do it with less issues. The difference between a good iron and anything else is impressive. I followed Leon's advice and I'm very happy with it.
    You can solder 0805 passives with a relatively big tip. Even a uSD adapter can be soldered with big tips. The only tricky parts on a propeller platform style PCB are the propeller, the ft232, and less crytical the usb adapter and the eeprom (one side is usually all grounded).
    For sure you need desolder braid, flux, and a nice solder station. Not less important are a support (panawise), tweezers and a magnifying tool.
    Every manufacturer has different requirements, mainly on file names. I try to use trace and clearance way above the manufacturer's minimum in every situation.
    Massimo
  • Mark_TMark_T Posts: 1,981
    edited 2012-12-11 19:16
    Well I've recently started using a stencil frame of my own design (detailed in post #44 in http://forums.parallax.com/showthread.php?130196-How-I-do-SMT-soldering-in-toaster-oven/page3&highlight=toaster+oven)
    First board I've done (before and after toaster oven) here:
    Have two different sets of precision tweezers and magnifying lens to get parts placed - very happy with the stencil frame though,
    the PCB shop I use provides free laser stencils ;)
    The kind of solder paste placement I get is like this (different board) but sometimes have to redo if its smudged or pads are missing.
    I set the toaster oven to "150C" nominal for a few minutes to prewarm and then full power whilest watching carefully - works nicely.
    692 x 722 - 171K
    722 x 756 - 225K
    620 x 864 - 106K
    edited 2012-12-11 20:16
    max72 wrote: »
    Massimo
    Since I've never had a PCB made it's my thought to call the company and discuss what it is they require from me to make a board.
    edited 2012-12-11 20:52
    4x5n wrote: »
    Why call? There are numerous tutorials online on making a PCB in the software of your choice. Here is one for KiCad: http://teholabs.com/knowledge/kicad.html
    In any case, the board houses are fairly standardized. They need gerber files for:
    1) Top copper*
    2) Bottom copper
    3) Top Soldermask
    4) Bottom Soldermask
    5) Top Silkscreen
    6) Bottom Silkscreen
    And a drill file:
    2.5) .drl
    Every PCB house will have some sort of capabilities page, such as this one from Advanced Circuits: http://www.4pcb.com/pcb-capabilities.html
    Just add some money, and you'll have a board in your hands in a few days.
    edited 2012-12-11 21:00
    Also, your PCB CAD software should have a facility for automatic design-rule checking. IOW, once your board is laid out, you should be able to click a button or menu item and have it scan the board for crossed traces, pads/traces too close, copper too close to the board edge, traces too thin, etc. If it doesn't sport this necessary feature, you need to investigate better CAD software, since this facility alone can save you beaucoup bucks.
    edited 2012-12-12 05:27
    Check the web sites, as suggested. You'll find the board requirements.
    Mainly the layer naming convention, and the minimum sizes. Sometimes you have a predefined drill set too.
    With Diptrace you can set the values in the DRC rules for automatic check.
    If you are not in a hurry check services like Itead.
    They are so insanely cheap that a test run cannot hurt.. :-)
    Massimo
