Getting 24 volts out of an ATX power supply.
I have motors that require 24 volts. Until I get batteries that output 24 volts, I'm thinking of using the motors in a tethered mode to prove out some ideas. I have an idea about how to supply them with 24 volts, but I'd like to ask if it would work before I risk smoking something. I have an old ATX power supply which have +12 and -12 volt rails. Can I use the -12 volt rail as a virtual ground and use the 24 volt potential between them to power the motors?
Don't forget you could also put two identical 12 volt supplys in series to get the 24 volts.
Cheers,
Just out of curiosity: do the ATX power supplies share a common ground? That would invalidate the simple series hooking of the two supplies, since it would create a short. This post seems to indicate that is the case: http://electronics.stackexchange.com/questions/7657/24v-3a-from-atx-power-supply
I just read that thread and I would tend to think that the AC sides share a common ground, but the DC sides would not. So they could be put in series. One person responded that they tried it and it worked.
I also found out that the -12 volt rail is generally rated at a quarter amp, so it wouldn't work for motors.
Good point. I think I could test this with a continuity tester? If the DC ground wasn't connected then this couldn't be the case?
What do you mean spares? Spare 12V wires do not mean seperate rails. Most supplies now come with two or more 12V rails, but you would have to ensure that these are on seperate rails to get 24V.
Bruce
Transformers - http://www.mpja.com/Transformers/products/45/
Bridges - http://www.mpja.com/Bridges/products/111/
And either get your capacitors at the same place or RS
EDIT: And 2A wall warts ain't cheap
I don't know how much amperage you need, but if you might consider making your own linear power supply, and don't need more than 2A per motor, then these two items in addition to a capacitor should get you some power close to 24V
http://www.mpja.com/18V-2A-Center-Tapped-9-0-9-Transformer/productinfo/7843+TR/
http://www.mpja.com/6A-50PIV-Square-Bridge-Rectifier-Wire-Leads/productinfo/5241+BR/
V (Peak) D.C. = 1.41 X Sec. V A.C.
V (Avg) D.C. = 0.90 X Sec. V A.C.
I D.C. = 0.62 X Sec. I A.C.
I have attached some information for your consideration.
http://www.mpja.com/24-Volt-Power-Supply/products/541/
Now you know as well as I do that Christmas is a long way off for those that need to experiment and tinker NOW
In the meantime, he could also just ask a couple of friends to borrow one of thier extra automotive batteries. Two of them and he would be good to go until Santa delivers the goods.
Those will probably come, but I want to build a proof of concept on the cheap before I invest the money for the SLA's
