programming ping))) on a boe bot
I have been trying to program a boe bot with ping in it but every time it works it has a very shaky n a very slow movement.
Please help!
below is my code!
' {$STAMP BS2}
' {$PBASIC 2.5}
Ping PIN 15
PingServo PIN 14
LeftServo PIN 13
RightServo PIN 12
rawDist VAR Word
sweepcount VAR Word
x VAR Byte
pulseCount VAR Byte
Main:
FOR sweepcount = 350 TO 1150 STEP 200
FOR x = 0 TO 5
PULSOUT 14, sweepcount
PAUSE 0
NEXT
GOSUB GetSonar
NEXT
FOR sweepcount = 950 TO 550 STEP 200
FOR x = 0 TO 5
PAUSE 0
NEXT
GOSUB GetSonar
NEXT
GOTO Main
GetSonar:
LOW Ping
PULSOUT Ping, 5
PULSIN Ping, 1, rawDist
IF (rawDist < 600) THEN
IF (sweepcount < 750) THEN
GOSUB Turn_Left
ELSEIF (sweepcount > 750) THEN
GOSUB Turn_Right
ELSE
GOSUB Back_Up
ENDIF
ELSE
GOSUB Forward_Pulse
ENDIF
RETURN
Forward_Pulse:
FOR pulsecount = 0 TO 5
PULSOUT LeftServo, 850
PULSOUT RightServo, 650
PAUSE 0
NEXT
RETURN
Turn_Left:
FOR pulseCount = 0 TO 10
PULSOUT LeftServo, 650
PAUSE 0
NEXT
RETURN
Turn_Right:
PULSOUT RightServo, 850
PAUSE 0
NEXT
RETURN
Back_Up:
FOR pulseCount = 0 TO 3
PULSOUT LeftServo, 750
PULSOUT RightServo, 750
PAUSE 0
NEXT
FOR pulseCount = 0 TO 7
PAUSE 0
NEXT
RETURN
Please help!
below is my code!
' {$STAMP BS2}
' {$PBASIC 2.5}
Ping PIN 15
PingServo PIN 14
LeftServo PIN 13
RightServo PIN 12
rawDist VAR Word
sweepcount VAR Word
x VAR Byte
pulseCount VAR Byte
Main:
FOR x = 0 TO 5
PAUSE 0
NEXT
GOSUB GetSonar
NEXT
FOR x = 0 TO 5
PAUSE 0
NEXT
GOSUB GetSonar
NEXT
GOTO Main
GetSonar:
LOW Ping
PULSOUT Ping, 5
GOSUB Turn_Left
GOSUB Turn_Right
ELSE
GOSUB Back_Up
ENDIF
ELSE
GOSUB Forward_Pulse
ENDIF
RETURN
Forward_Pulse:
PAUSE 0
NEXT
RETURN
Turn_Left:
PAUSE 0
NEXT
RETURN
Turn_Right:
PAUSE 0
NEXT
RETURN
Back_Up:
PAUSE 0
NEXT
PAUSE 0
NEXT
RETURN
Zero is wrong! Servo need a 1ms to 2ms (with some latitude) pulse every 20ms. The PAUSE 20 gives the needed pause between pulses.
Are you looking at some example code? It seems like your sweeps may be too large (but not outrageous). I think you should try to keep your sweeps between 500 and 1000 (1ms and 2ms).
Are your batteries fresh or freshly charged? A lot of servo problems are the result on batteries not providing enough current.
What do you mean by "jerky"? Is just the Ping servo jerky or are the drive servos also jerky? The Ping servo moves in rather large jumps. You can make it change by smaller abouts by using smaller steps. To change the step change
to
or some other number. This will make the Ping servo turn in smaller amounts.
' {$STAMP BS2}
' {$PBASIC 2.5}
Ping PIN 15
PingServo PIN 14
LeftServo PIN 13
RightServo PIN 12
rawDist VAR Word
sweepcount VAR Word
x VAR Byte
pulseCount VAR Byte
Main:
FOR sweepcount = 350 TO 1000 STEP 20
FOR x = 0 TO 5
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
FOR sweepcount = 950 TO 1000 STEP 20
FOR x = 0 TO 5
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
GOTO Main
GetSonar:
LOW Ping
PULSOUT Ping, 5
GOSUB Turn_Left
GOSUB Turn_Right
ELSE
GOSUB Back_Up
ENDIF
ELSE
GOSUB Forward_Pulse
ENDIF
RETURN
Forward_Pulse:
PAUSE 20
NEXT
RETURN
Turn_Left:
PAUSE 20
NEXT
RETURN
Turn_Right:
PAUSE 20
NEXT
RETURN
Back_Up:
PAUSE 20
NEXT
PAUSE 20
NEXT
RETURN
Have a look at the Roaming with the PING example. This uses a number of techniques to keep the pulses flowing.
Another option is to use a servo controller like the Propeller Servo Controller to handle the generation of the pulses. There used to be another controller called the ServoPAL, but it's discontinued at this time.
