Professional Development Board LED Display
My disclaimer.... I'm a really new beginner.
I bought the Professional Development Board quite a while back and I'm just now getting the opportunity to try it.
Its the Rev A Part Number 321111 and has the white test board on it.
I would like to see if I can light up the multi segment led display that's on the board.
Can anyone tell me how to accomplish this?
Thanks!
Thanks!
The above comments about "bar" and "triangle" refer to how LEDs are shown on schematics. On page 3, the schematic uses a picture of the display digits without the schematic symbol for an LED. You'll see if you look on other pages with LEDs shown.
If you're interested and can't find the thread, let us know. One of us might remember enough key words to help you find it.
I think those 16-segment displays look really cool but I rarely use them. It's so much easier to output to a terminal window, TV or serial LCD.
So any help with that PCB would help.
Thanks!
http://forums.parallax.com/showthread.php?129182-New-LED-driver-for-PPDB-Now-Available&highlight=development+board
I have one of the boards and am happy with it. Simplifies the wiring and you only need a few Propeller pins to drive all the displays.
Robert
http://youtu.be/LriHbhNR0TI
To order one:
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=NVXC2URAZ8CS4
Do you have the latest drivers for both versions?
Just PM (with any new address etc) and will check my order records for a match.
here is the old thread for it.
http://forums.parallax.com/showthread.php?134106-Updated-17seg-LED-driver-for-PPDB-now-available.
Why? I have two of the three wire boards and they work just fine. I feel like I got what I paid for.
It would be fun to try a one wire board (an interesting idea) so I'll probably send you a PM but I sure don't feel like you owe me anything.
Very generous offer, Tony. I fell pretty much the same as Duane. I have one 3 wire and would only be getting the one wire to play with. It's people like you on the forums that make this a special place!
The 3wire 17Seg was the first product that got me started in pcb design and this is my holiday gift.
As as Prop pins are valuable, saving 2 pins is pretty important.
I will release the schematic soon, as you may want to use these type of 17seg LEDs in your own design one day.
Thank you for the gift. It makes me feel better to think of it that way. I didn't want you to feel like you owed us(me) anything.
I use shift registers in a lot of my projects, it will be interesting to see if I can use your method to save a couple of pins. I assume the one pin trick is only an option when refresh rate isn't critical (you don't need to explain this to me, I'll go read the other thread).
Does anyone have a good source for 16-segment displays? IIRC, I think Parallax had to test each module and grouped them by brightness so each PPDB had modules with matching brightness levels.
I purchased some surplus modules when I was new to microcontrollers (a few years ago) but they were 14-segment instead of 16-segment displays. The extra two segments are important in getting good looking characters. As I mentioned earlier in this thread, other display types are generally easier to use than these displays but I think these look really cool and I'd like to find a source of display modules so I can start including them in my projects.
Thank again Tony.
