KA BoeBot Project — Parallax Forums
KA BoeBot Project
MoutasemMoutasem Posts: 11
edited 2013-02-10 05:24 in Learn with BlocklyProp
This thread is for my teacher, my classmates and I to communicate with each other.
04/12/2012
  • Mark KiblerMark Kibler Posts: 546
    edited 2012-12-03 22:30
    Hi Moutasem. Thanks for starting the thread. This is where we'll meet (virtually) to discuss our project ideas, post questions, and share informationm with others.
    L. Mark Kibler, M.Ed.
    Project mentor
    (formerly with project ARLISS)
  • shoman95shoman95 Posts: 3
    edited 2012-12-04 22:44
    Hi all, I am Moutasem's classmate! This thread, hopefully, will help us and guide us through our project. By Sunday, i will have three assignments laid out, i will have to pick one and start work immediately. Hopefully, after choosing a project to build, people can help me as i struggle.
    - hamza
  • MoutasemMoutasem Posts: 11
    edited 2012-12-10 10:09
    Hello Everyone,
    One of my project ideas is to build a Boe-Bot with multiple IR transmitters, and I might not have as many as I need. Would removing IR transmitters from a TV remote control work with the Parallax circuit-board and if so does it work on the same frequency?
    Thank you.
    Moutasem.
    edited 2013-01-07 21:10
    Welcome, guys! I'm not sure if you want or need any outside help, but if you do, you're in a very friendly forum. We especially like to help those who are helping themselves and getting an education in the process. If you need help or have questions, just post in the appropriate forum, probably general, stamp, education or robotics forum. Good luck!
    edited 2013-01-21 22:24
    Hi Erco,
    Thanks for your reply. I'm waiting for and encouraging my guys to post to the forum so they can network with other programmers and electrical engineers. Two are high school seniors, headed off to university in September to study engineering and they need to know how to do this.
    One of them built a BOE-bot that has a camera integrated into it. Its purpose is to navigate a square (30 x 30 x 30 x 30 meter) obstacle course, record imagery and return to the lab unassisted. The other is building a simple SHT chip circuit board that measures and records temperature, humidity, and time. Any suggestions you can offer us are very much appreciated.
    On another note to those of you who follow our progress and know about project ARLISS, one of the student project members was just accepted at WPI with a scholarship and he has applied to NASA for a summer (high school internship.
    Thank you, Parallax Inc., for all of your encouragement and support. Because of your support a number of my former students are attending top universities, some with scholarships, and studying fields like aerospace science and engineering,
    Best regards,
    Mark Kibler
    edited 2013-01-29 10:23
    Hello Everyone,
    Erco, thank you for your post and warm welcome. Moreover, I would keep you guys updated with my project here from now. The IR transmitters on my boe-bot seem to be working fine, but my problem is that its not navigating through the halls like it is suppose to. It now is simple avoiding crashing into objects, and depending on the objects in the hallway it either follows the correct path or not. Do you think if I was to program it to move a certain distance (the distance of the hallway) and avoid hitting objects would be a good idea? Do you have any other ideas?
  • mbairmbair Posts: 3
    PROGRAM CODE FOR SHT, RTC, DATA LOGGER DEVICE
    KAT
    MEASURES AND RECORDS TEMPERATURE, HUMIDITY, AND TIME
    ' {$STAMP BS2e}
    ' {$PBASIC 2.5}
    Program Description
    ' This program measures and records temperature, humidity and time using
    ' a data logger. The data collected will be saved as a txt file in a USB.
    ' I give credit to the ARLISS team and Tracey Allen for writing the origonal program,
    ' I only modified it.
    I/O Definitions
    ShtDta PIN 1 ' Data pin (HS)
    ShtClk PIN 0 ' Clock Pin (HS)
    DSclk PIN 3 ' Sclk (HS)
    DSdta PIN 5 ' I/O (HS)
    DSce PIN 7 ' request to send (HS)
    TD PIN 8 ' TD (HS)
    RTS PIN 9 ' RTS (HS)
    RD PIN 10 ' RD (HS)
    CTS PIN 11 ' CTS (HS)
    Constants
    SBR CON 84 ' SBR (Serial baud rate) for datalogger (HS)
    ShtTemp CON %00011 ' temp command (HS)
    ShtHumid CON %00101 ' humid command (HS)
    Ack CON 0
    NoAck CON 1
    logInterval CON 5
    DegSymbol CON 186 ' degree symbol (HS)
    Variables
    first VAR Word
    iobyte VAR first.BYTE0
    loopcounter VAR first.NIB2
    notused VAR first.NIB3
    tani VAR Word
    flags VAR tani.BYTE0
    ackbit VAR flags.BIT0
    SHTERROR VAR flags.BIT1
    DISKERROR VAR flags.BIT2
    LND VAR flags.BIT3
    tani0 VAR tani.BYTE1
    shoman VAR Word ' extra VAR (HS)
    soSHT VAR shoman
    soSHT0 VAR soSHT.BYTE0
    soSHT1 VAR soSHT.BYTE1
    Tout VAR shoman ' Sensirion timeout (HS)
    degreeC VAR Word ' temp Cx10 (HS)
    rh VAR Word ' humid %x10 (HS)
    time0 VAR Word
    sec VAR time0.BYTE0
    minute VAR time0.BYTE1
    time1 VAR Word
    hour VAR time1.BYTE0
    loopcounterx2 VAR time1.BYTE1
    buffer VAR Word
    buf0 VAR buffer.BYTE0
    buf1 VAR buffer.BYTE1
    Initialization
    OUTS = %0001001000000000
    DIRS = %1111001111111101
    GOSUB init_Message
    PAUSE 10
    GOSUB RTC_init ' reset clock (HS)
    PAUSE 1000
    GOSUB RTC_init
    PAUSE 512
    HIGH TD ' initialize TD (HS)
    LOW RTS
    PAUSE 512 ' 0.5 second pause
    GOSUB V_synchronize ' ready to send (HS)
    DEBUG CR,"synchronizing: ",DEC shoman
    GOSUB V_short_commands ' short command mode (HS)
    GOSUB V_Check_Drive
    DEBUG CR,"disk tries: ",DEC shoman, CR
    IF DISKERROR=1 THEN
    DEBUG " device not found" ' If the USB is not plugged into the Data Logger,
    ELSE ' the screen will say "devise not found" (HS)
    GOSUB V_open_datafile
    SEROUT TD\CTS, SBR, [ $8,$20,0,0,0,10,CR,"KAT data",CR, LF]
    GOSUB V_purge
    GOSUB V_close_datafile
    ENDIF
    DEBUG CR," Run Time Sample# Humidity(%) Temp(C)",CR
    GOSUB SHT_Connection_Reset
    PAUSE 256
    Program Code
    Main:
    DO
    GOSUB RTC_sync
    loopcounterx2 = loopcounterx2 + 1
    DEBUG CR,HEX2 hour,":",HEX2 minute,":",HEX2 sec, TAB, DEC loopcounterx2
    GOSUB SHT_Measure_Temp
    GOSUB SHT_Measure_Humidity
    DEBUG TAB,REP "-"\degreeC.BIT15,DEC ABS degreeC/10,".",DEC1 ABS degreeC,DegSymbol
    DEBUG TAB, DEC rH/10, ".", DEC1 rH, "%"
    GOSUB V_write_record
    LOOP
    END
    RTC
    RTC_init:
    HIGH DSce
    SHIFTOUT DSdta,DSclk,LSBFIRST,[$8E,$00]
    LOW DSce
    HIGH DSce
    SHIFTOUT DSdta,DSclk,LSBFIRST,[$BE,$00,$00,$00,$04,$07,$09,$09,$80]
    LOW DSce
    RETURN
    rtc_Sync:
    buffer=loginterval*200
    DO:DO
    GOSUB RTC_read
    buffer=buffer-1
    LOOP UNTIL sec<>tani0 OR buffer=0 '
    tani0=sec
    LOOP UNTIL sec.NIB1*10+sec.NIB0//logInterval=0 OR buffer=0
    RETURN
    RTC_read:
    HIGH DSce
    SHIFTOUT DSdta,DSclk,LSBFIRST,[$BF]
    SHIFTIN DSdta,DSclk,LSBPRE,[sec,minute,hour]
    LOW DSce
    RETURN
    Vinculum/Thumb Drive
    V_purge:
    V_Get_Data:
    SERIN RD\RTS, SBR, 128, V_Timeout, [STR buf0\12]
    V_Timeout:
    RETURN
    V_synchronize:
    shoman=0
    DO
    GOSUB V_purge
    PAUSE 256 ' 0.25 seconds wait
    SEROUT TD\CTS, SBR, ["E", CR]
    GOSUB V_get_Data
    shoman=shoman+1
    LOOP UNTIL (buf0="E" AND buf1=CR) OR shoman=8
    GOSUB V_purge
    SEROUT TD\CTS, SBR, ["e", CR]
    GOSUB V_get_Data
    IF (buf0<>"e" OR buf1<>CR) THEN shoman=shoman + 1
    IF shoman>7 THEN DISKERROR=1
    RETURN
    V_Check_Drive:
    shoman=0
    DO
    GOSUB V_purge
    SEROUT TD\CTS, SBR, [CR]
    GOSUB V_get_Data
    IF buf0="N" AND buf1="D" THEN
    shoman=9 ' if disk = 9 then disk not found (HS)
    EXIT
    ENDIF
    shoman=shoman+1
    PAUSE 100
    LOOP UNTIL buf0=">" OR shoman=8
    RETURN
    V_short_commands:
    SEROUT TD\CTS, SBR, ["SCS", CR]
    GOSUB v_get_Data
    RETURN
    V_Open_DataFile:
    GOSUB V_purge
    SEROUT TD\CTS, SBR, [$09, $20, "datafile.txt", CR]
    GOSUB V_purge
    RETURN
    v_Close_DataFile:
    GOSUB V_purge
    SEROUT TD\CTS, SBR, [$0A, $20, "datafile.txt", CR]
    GOSUB V_purge
    RETURN
    V_write_record: ' write data int USB as a txt file (HS)
    SEROUT TD\CTS, SBR, [ $8,$20,0,0,0,23,CR, HEX2 hour, ":" , HEX2 minute, ":", HEX2 sec, "," ,
    degreeC.BIT15*13+32,DEC3 ABS (degreeC/10),".", DEC1 ABS degreeC,",",DEC3 (RH/10),".",DEC1 RH, CR, LF]
    GOSUB V_purge ' 23 was 29 but subtracted 6 to delete the altitude
    RETURN ' from the USB flash drive (HS)
    Sensirion
    SHT_Connection_Reset:
    SHIFTOUT ShtDta, ShtClk, LSBFIRST, [$FFF\9]
    RETURN
    SHT_Start:
    INPUT ShtDta
    LOW ShtClk
    HIGH ShtClk
    LOW ShtDta
    LOW ShtClk
    HIGH ShtClk
    INPUT ShtDta
    LOW ShtClk
    RETURN
    SHT_measure:
    GOSUB SHT_Start
    GOSUB SHT_Write_Byte
    GOSUB SHT_Wait
    ackBit = Ack
    GOSUB SHT_Read_Byte
    soSHT1 = ioByte
    ackBit = NoAck
    GOSUB SHT_Read_Byte
    soSHT0 = ioByte
    RETURN
    SHT_Measure_Temp: ' temp program for measuring data (HS)
    ioByte = ShtTemp
    GOSUB SHT_measure
    degreeC = soSHT / 10 - 400 ' covert celsius to 10ths (HS)
    RETURN
    SHT_Measure_Humidity: ' humidity program for measuring data (HS)
    ioByte = ShtHumid
    GOSUB SHT_measure
    rh = (soSHT ** 26542)
    rh = rh - ((soSHT ** 3468) * (soSHT ** 3468) + 50 / 100)
    rh = rh - 40
    rh = ((degreeC + 250 / 10 - 50) * (soSHT ** 524 + 1) + (rh * 10)) + 5 / 10
    RETURN
    SHT_Write_Byte:
    SHIFTOUT ShtDta, ShtClk, MSBFIRST, [ioByte]
    SHIFTIN ShtDta, ShtClk, LSBPRE, [ackBit\1]
    RETURN
    SHT_Read_Byte:
    SHIFTIN ShtDta, ShtClk, MSBPRE, [ioByte]
    SHIFTOUT ShtDta, ShtClk, LSBFIRST, [ackBit\1]
    INPUT ShtDta
    RETURN
    SHT_Wait:
    INPUT ShtDta
    Tout = 255
    DO
    Tout=Tout-1
    PAUSE 1
    LOOP UNTIL ShtDta=0 OR Tout=0
    IF Tout=0 THEN
    SHTERROR=1
    ENDIF
    RETURN
    init_message:
    DEBUG CR,"Hamza Shouman - King's Academey - APR 17 13", CR, CR
    DEBUG "Temperature, humidity, and data logging program",CR, CR
    DEBUG "KAT", CR, CR
    RETURN
