How to output one bit to a pin?
How do you take the LSB in a byte and outa[x] to a particular pin? Ive thought of a few ways to use logic operators that may accomplish this goal, but each of these seemed too cumbersome. I may be lost in the woods and missing the obvious. Thanks in advance for some guidance. Tom
This is assuming you're working in SPIN. If PASM let me know and I will post example for that too!
outa[x]:= variable
SPIN takes care of using the LSB. This is because the pin in [] can also be a range, so outa assignment already has work with a flexible number of bits and has to mask out the bits that are not needed.
You're probably right about that! I've spent too much time in PASM lately...
outa[x]:= variable works just fine.
Also thanks for the explanation, MagIO2.
I must have missed that point in the PEK Labs: Fundamentals book.
