info on using rssi data to do antenna tracking?
ok so ive been looking into using rf as a means of tracking as suggested by another member. i guess the plan is to use rssi to determine the direction and strength of the signal. im not sure what ill be using for beacons probably nordic 2.4 based boards.
for right now i want to track my bots location using its hc05 bluetooth. the data sheet says you can run an at command to get rssi data. now i dont know what rssi data looks like or what kind of alogorythms are used to determine distance or direction..
i searched google for rssi based tracking and turned up a few rc sites and pdfs that were super vague. i was hopping someone could shed some light on what to do with the rssi to turn it into useful tracking data
http://youtu.be/QgN8kpS3DME
The best way to track something would be multiple methods, using just RSSI alone will be cumbersome
antenna like a long Yagi or parabolic dish. You need a carefully engineered antenna away from all other influences, perhaps a small
2-element dipole antenna array stuck up a pole with a stepper motor to rotate it. You'd need to calibrate the null-points of the antenna
and try to make sure the nulls are insensitive to changes in polarisation. And you'll need some way of identifying which null point is which... Bit tricky
I think, good luck.
