Xbee Help, values not transmitting — Parallax Forums
mhamen3mhamen3 Posts: 69
edited 2012-11-30 13:30 in Propeller 1
Hi Guys,
I'm having trouble getting my xbees to communicate from prop to prop. I'm working on a remote control and I can't seem to get the signals from my controller to be read on my robot.
I've checked the obvious, each is receiving 3.3V, Dout is connected to the XB_Rx pin and Din is connected to the XB_Tx pin, and I've tested the xbees with the x-ctu software to make sure they are actually working.
Below is my code for the transmitter and receiver:
Transmitter
CON
   _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  cpin = 0
  dpin = 1
  spin = 2
  XB_Rx = 26
  XB_Tx = 27
  XB_Baud = 9600
VAR
   Long Sldr[6]
   Long Gmbl[6]
OBJ
  ADC   : "MCP3208"
  PST   : "Parallax Serial Terminal"
  XB    : "Xbee_Object_2"
Pub Start
XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize comms for XBee
  repeat
      Sldr[1] := ADC.average(0,10)
      Sldr[2] := ADC.average(1,10)
      Sldr[3] := ADC.average(2,10)
      Gmbl[1] := ADC.average(3,10)
      Gmbl[2] := ADC.average(4,10)
      Gmbl[3] := ADC.average(5,10)
      Gmbl[4] := ADC.average(6,10)
      IF Gmbl[4] > 2500
        Gmbl[4] := 1
      ELSE
        Gmbl[4] := 0
      XB.Tx("!") ' Send start delimiter
      XB.Dec(Sldr[1])
      XB.CR
      XB.Dec(Sldr[2])
      XB.CR
      XB.Dec(Sldr[3])
      XB.CR
      XB.Dec(Gmbl[1])
      XB.CR
      XB.Dec(Gmbl[2])
      XB.CR
      XB.Dec(Gmbl[3])
      XB.CR
      XB.Dec(Gmbl[4])
      XB.CR
Receiver
CON
  XB_Rx = 26
  XB_Tx = 27
  XB_Baud = 9600
VAR
   Long Sldr[6]
   Long Gmbl[6]
OBJ
Pub Go | DataIn
   XB.Start(XB_Rx,XB_Tx,0,XB_Baud)
   PST.start(115200)
   PST.str(string("Awaiting Data..."))
  Repeat
   DataIn := XB.Rx ' Accept incoming byte
   If DataIn == "!" ' If start delimiter
      DataIn := XB.RxDecTime(500) '
      if DataIn <> -1 ' If wasn't time out
        Sldr[1] := DataIn
      if DataIn <> -1
        Sldr[2] := DataIn
      if DataIn <> -1
        Sldr[3] := DataIn
      if DataIn <> -1
        Gmbl[1] := DataIn
      if DataIn <> -1
        Gmbl[2] := DataIn
      if DataIn <> -1
        Gmbl[3] := DataIn
      if DataIn <> -1
        Gmbl[4] := DataIn
      PST.str(string("   Sldr 1 ="))
      PST.dec(Sldr[1])
      PST.str(string("   Sldr 2 ="))
      PST.dec(Sldr[2])
      PST.str(string("   Sldr 3 ="))
      PST.dec(Sldr[3])
      PST.str(string("   Gmbl LR ="))
      PST.dec(Gmbl[1])
      PST.str(string("   Gmbl UD ="))
      PST.dec(Gmbl[2])
      PST.str(string("   Gmbl ROT ="))
      PST.dec(Gmbl[3])
      PST.str(string("   Gmbl Btn ="))
        IF Gmbl[4] == 1
                PST.str(string("ON"))
        ELSE
                PST.str(string("OFF"))
        PST.newline
So I'm just trying to get the values from my remote to be read on my receiver and printed to the PST.
Any help would be much appreciated
Marc
  • StephenMooreStephenMoore Posts: 188
    edited 2012-11-28 20:14
    Looks to me like your transmitter may be slamming the radio a bit hard. Try putting a waitcnt(clkfreq / 4 + cnt) in the loop to allow the UART to handle the data flow.
    Also your receive loop will fall through on timeouts and may mess up your data sync. Just use xbee.rx instead and make sure you are actually sending data to get you out of the receive mode.
    If the radios are working in XCTU then you have them set up fine.
    Try transmitting from one prop to XCTU terminal as a check and from XCTU to the receiver prop as well.
    Good luck.
    sm
  • mhamen3mhamen3 Posts: 69
    edited 2012-11-29 06:22
    Thanks Stephen, I appreciate the help.
    Don't know exactly why, but when I used Full duplex serial on the TX side instead of the xbee object, it worked.
