PCB electrro-magnet
Has anyone ever made a PCB electromagnet?
I was wondering if I could design a coil on a PCB and use it to make electromagnetic fields to spin another magnet above the PCB.
Ideas?
Ideas?
Have a look at this discussion on Electro Tech Online. It might help.
Cheers
You can always etch a spiral coil onto a PCB and use that to attract a metal object or other magnet.
Then you can imagine many such coils in some circular arrangement to make a motor.
Problem is the efficiency is low because of the gap between coil and its armature. Also you cannot pump much current through the PCB coil as the guy in the video found out.
You may be able to get the thicker copper plating on the PCB material so you can get a higher current through it. I have a couple OSMC motor controller boards that had heavy copper plating due to the current those boards were made to handle.
Robert
Would it be better to make the coils on the PCB round or will 45 degree angles be sufficient? I cant seem to make rounded traces using my over priced layout software. I know this is a problem for some circuits but this might work none the less.
http://www.diptrace.com/forum/viewtopic.php?f=4&t=172&p=731&hilit=spiral#p731
Check out pcbmotor.com They have dev kits with motors and controllers that may meet what you are looking for.
http://www.youtube.com/watch?v=PVwWtSPni-U&list=UU70dOqAKSlpbIxvmb4ncM-w&index=2&feature=plcp
FF
Well, have you ever taken apart an old diskette drive?
Take a look at the motor spinning the disk.
They're mostly inductors mounted on a PCB...
I do get an idea how it could possible be done.
http://www.beyondthejunkpile.com/2012/07/motor-winding-magic.html
THAT is a cool idea
