PWM Signal VS R2R latter or DAC chip for motor speed.
So i had this idea and i was unable to find much on the topic via google. What if one were to generate motor control signal via a propeller/resistor based dac, or a nice 12 bit stand alone dac chip instead of just sending a PWM signal off to the hbridge? It seems to me like maybe you could get alot more accuracy and a very smooth ramp using a 12 bit dac chip to generate the motors speed signal. Is there any reason people dont genrally use a nice dac in motor control applications?
Going beyond that vague advice, you'd have to know the inductance of the motor windings and how much ripple current you could tolerate, then compute the frequency that would give you that. IMO, it's not worth the trouble.
Phil, if you go too high on the frequency, the windings being inductors will have an increasing impedance to the point your motors performance will begin to degrade as well?
FF
