Robo Magellan
Below is a functional description / specification for my project. The first three items are included in the current program version shown in the link below. The remaining items are future functions that I intend to add once I get a handle on starting methods in cogs as described in the link below.
Support the use of hobby grade servos and speed controllers.
Support an LCD display to display real time data of selected information depending upon the mode of the program. There will be multiple screen displays depending upon the operation performed. The LCD screen displayed at startup will be different than the display during compass calibration which will be different than the LCD displayed while traversing to a way point, etc.
Support the monitoring of actual motor speed via the Hall Effect sensor Cruise_Control so that the bot speed is some what constant over grass or pavement
Future Functionality
Support the ability to determine distance traveled via the Hall effect sensor.
Support collision avoidance via PING sensor.
Support the use on an onboard compass module and its calibration at program start.
Support the use of GPS to determine location, speed, heading, etc.
Support un-tethered programming and real time monitoring of selected program variables. This is to be accomplished using VP and the Blue Tooth radio at some point. My use of the term real time may not be precise in engineering terms but its close enough for my purposes.
Support the use of an SD card reader to store and retrieve way point data.
Support the use of a 4x4 keypad to enter data as required.
Right now the project consists of an RC truck platform and the code is in the early development stages with the indiviual components connected to a development board. Once I get the code to a more work able level I will post.
My original questions and thread posts are at the link below:
http://forums.parallax.com/showthread.php?144024-Program-Architecture-Best-Practices-with-Multiple-Objects-and-Cogs
Steve
Steve
http://www.chibots.org/?q=node/435
This one is by Chicago. Anybody else doing this competition these days?
Steve
Agreed, getting all the plates spinning simultaneously and in sync is a big systems challenge. Any one piece of the puzzle might be easily understood, but trying to get everything work together seamlessly can be, well, trying.
This is what I am using.
Rick Brooks
With the rover, I took a systems engineering approach to my build and it was helpful to keep all the many issues, ideas, parts, and pieces somewhat orderly. I found it helpful to draft a "functional architecture" which abstracted some of the design details.
That is, categorize the various functionality to help keep it all straight. E.g., "navigation" abstracts compasses, encoders, navigation algorithms. "Odometry" abstracts hall effect sensors or wheel encoders, etc. "UI" abstracts LCD display and any input buttons. I mention this because such an effort is really R&D with a lot of R then re-D, then more R, then more re-D.
For example, you may assume you want a hall effect sensor only to find that it doesn't work quite like you thought and you want optical. Or you decide to ditch odometry and just use GPS, or just use optical flow, or... ??? Having a way to keep track of all the design ideas, design options, etc., was very helpful for me.
I used a variety of informal means of keeping all these things documented. Freemind (mind mapping tool) helped to sort of structure the hierarchy of categories. I also used OpenOffice to write a document in outline format for similar purpose. Whatever works to keep it all straight.
Another thing I've found helpful is to start thinking in the time scale of the robot and very carefully considering timing of everything. How often do sensors update. How often do the various code loops run. An example: if some control loop runs at, say 100hz, and it commands a change to a steering servo... and that servo swings 60° in 0.19sec, how many loops before the brain starts to see any kind of change in direction?
One last thing that I found important was to take a sort of Wright Brothers approach and break the problem down and thoroughly understand and test each problem. Like, understanding (through mathematical calculations) just how much heading error results from using a 2d compass in a 3d world with the robot tilted at various angles and in various directions. That kind of thing.
I hope this is of help in some way. More info on my rover, Data Bus, here: http://www.bot-thoughts.com/2011/05/data-bus-nickle-tour.html
Thank You. Rick, you gave a presentation at Chibots a year or two ago, that was a real inspiration to me. The idea was running loose in my head but your work proved that it was practical and do able even w/o CCD vision. As work progresses, I will be reaching out for you.
Regards
Steve
Post your questions and I'll keep and eye on this thread.
All of my code came from the forum and OBEX and I hope that I documented it all good enough to trace it back to the original posting.
Rick
Still a few more features to add, but progress is being made. I'll post code and drawings once I get things in a more presentable form.
Best Regards,
Steve
http://www.youtube.com/watch?v=ft1SFeAYVuI
It's actually quite a challenge to create the hardware/software to drive at a consistent speed/heading over grass/snow - you make it look super easy!
I love the ME touches of handles and "clothes hangers". Did you have any issues getting accurate compass readings while it bounces around?
I've attached some sun and warmth from here- beautiful beach day!
H
The hooks are used to hang the bot from a sling so that it can be rotated flat to calibrate the compass. A few loops about 4' long and I can pick up the bot and flat spin it easily.
The compass has worked pretty well so far, and I only make the heading hold accurate to within 10 degrees or so. Less time spent hunting back and forth for the EXACT azimuth. The trickiest part so far was the set of If statements needed to hold a course around 0 degrees. A little right is 5 degrees, a little left is 355. Typical error logic will not work. The solution I came up with will be in the posted code.
The PID was straight from Hanno's 12Blocks. Just a few lines of code, but its ccompact and easy to use. The Hall effect sensor works great at detecting the set screws in the plastic servo wheel. I chose this method over encoders, for it's simplicty. I have about a 1 cm resolution which as far as I can tell is enough.
The next hurdle is determining how to get from one way GPS point to another. Soon!
Steve
Anyway, there is a heading hold routine that always attempts to steer to a particular azimuth. The heading hold routine only maintains an accuracy of about 10 degrees (arbitrary) to avoid excessive hunting. There is also a PID routine(cruise control) that keeps the wheels turning at a constant speed , more or less. The PID gets it's info from the Hall effect sensor. The same Hall effect sensor also provides the pulse count for dead reckoning. To turn a circle, I just keep changing the heading hold azimuth through a " repeat index from 0 to 359 step 1 " loop.
The Hall effect sensor is set up with a magnet in "gear tooth" mode. It's described in the data sheet. For "gear teeth" I put a bunch of itty bitty (4x40x1/8) set screws in a servo wheel and attached to the trucks transmission clutch. Not real pretty, but darned effective.
WHAT I DO NEED help with right now is a simple reliable routine that takes the current GPS position and the desired GPS position, and calculates the required heading and distance between the two.
If anyone can provide some guidance, I would apreciate it.
Best Regards,
Steve
I can help you with the lat/lon code. Take a look at this C++ object I put together for my Data Bus robot. It has several member functions that might be useful. You can calculate bearing/distance from one point to the next. You can calculate a new point given a bearing and distance travelled.
https://mbed.org/users/shimniok/code/GeoPosition/
Translating this to Spin wouldn't be too hard as it's really just math wrapped by a C++ class. Let me know if I can help further.
This is the code I was using in 2011 through to a month or so before the 2012 AVC. I then converted the approach.
Instead of using lat/lon, I converted my waypoints and gps reported position to cartesian coordinates. Then I did all the bearing/distance calcs with simple trig, rather than the Haversine formula used in the object linked above. The main reason was calculation performance for my custom sensor fusion. I'd be glad to provide more detail if you are interested.
However, could we get some better coverage of the set screws embedded into the wheel system?
Where ever did those come from? Did you build that? or did you git those at the gitten place? kin i git some too?
seriosly, the whole assembly looked very slick, at least from the .01 seconds of video.
I mean that I really like them, and would like to steal see more of them.:thumb::thumb:
Very cool project, Thanks for sharing.
-Tommy
Steve
perfectly spaced slots in a disk, and here the whole time I coulda been using a jig I allready have that will drill evenly spaced holes..
This forum is awesome, Keep up the good work.:thumb:
-Tommy
Its true RC stuff is way exspensive, originally i thought about buying alot of my stuff at the rc shop but it was just to much, especially for plastics. It looks like your using the same truck ive been thinking about its about 100 but just has an awesome suspension for the price and an ugly body.
I believe this is referred to as " hunting". I can't get the GPS to refresh any faster so the only solution I can think of is to stop the robot, take a reading, turn the robot then move forward again. I'm interested to know how others handle this.
Use the compass to steer the robot, not the GPS.
The compass can update very quickly. The steering with compass control loop should be about 20 to 50 msec. In the steering control loop, compare the present compass reading with the previous GPS heading and correct the steering.
That way the steering will be updated 10 to 50 times a second while the GPS will update the destination direction every second.
Rick Brooks
I ran into this exactly problem back in mid-2012. http://www.bot-thoughts.com/2012/05/avc-whats-wrong-with-data-bus.html
In fact, the GPS is likely providing you old data. The two GPS units I've used provided data 1 second old. Even the Venus running at 10Hz still provided 1-second-old data.
The short answer is, steer off your compass, yes. But if you plan to fuse position/heading data, I believe you have to deal with this lag.
I compensated for the lag as described in detail here: http://www.bot-thoughts.com/2012/07/avc-heading-and-position-estimation.html
The short summary is, lag the "new" data to match the lagged data, fuse it, then use the error to correct the new data, then make a control decision (steering)
LMK if I can provide more / better explanation
https://www.youtube.com/watch?v=M8u0VsNM0II
Thank you to everyone for your help and support. An extra thank you to Rick Brooks for his sharing and a super extra thank you to Mr. Phil Pilgrim for this little code gem.
http://forums.parallax.com/showthread.php/122260-Quick-and-dirty-four-quadrant-integer-only-arctangent-in-Spin?highlight=atan2
There is still a bit more to do, but functionally I am done.
Regards
Steve
Steve
