basic servo help — Parallax Forums
basic servo help
drinkmasterdrinkmaster Posts: 1
edited 2012-11-24 21:46 in BASIC Stamp
Hello,
I am trying to get a servo to work with a basic stamp. I seem to be having trouble.... I have tried 3 different servos. Two Parallex CR servo and one HITEC hs-625mg not CR servo. No matter what I do i can't seem to get anything to work. As soon as I load the code to the basic stamp the HITECH will flutter, or the parallex will just rotate and won't stop. It doesn't seem to matter what code I use or even what pin i attach the servo to, but i have attached what I am using below. To power the servos I am using a 6v power supply rated at 300ma. Not the same supply has basic stamp, Could someone please help, it seems like a simple task.
Servo_pin CON 0
start:
   PULSOUT Servo_pin, 750
   pause 20
GOTO start
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-11-24 15:00
    Not sure about the other Servos, but for the Parallax Servos 750 is stooped. Try 850 and or 650.
    edited 2012-11-24 15:09
    More details.
    Which Stamp are you using?
    Are you also using a BoE (or what)?
    Do you have the negative lead of your 6V supply connected to Stamp Vss?
    A continuous rotation servo will keep rotating and a standard servo will keep a position, given the same pulse width with each refresh (cycle).
  • ajwardajward Posts: 1,130
    edited 2012-11-24 21:10
    Just a thought... have you centered your continuous servos? The "pulsout servo_pin, 750" command might not stop the servo if you haven't.
    Amanda
    First, use a 6V battery pack instead of your tiny adapter. You DID connect your grounds together? Negative Stamp (ground, Vss) connects to your servo's negative voltage. Then try this and report back, servo on pin 0:
    start:
    for b0=1 to 255
    PULSOUT 0, 650
    pause 20
    next
    for b0=1 to 255
    PULSOUT 0, 850
    pause 20
    next
    GOTO start
